GSR vs ITR vs SI valve cover
Old Oct 28, 2005 | 10:51 AM
vtec.dc2's Avatar
Default GSR vs ITR vs SI valve cover
I learned or.. heard recently itr valve cover is a bit taller, i know grommets are different on itr
i guess it makes no differnce, but if it does.. then.. why taller valve cover for itr vs gsr, and is it same height as civic valve cover?
Old Oct 28, 2005 | 11:00 AM
Jowee's Avatar
Default Re: GSR vs ITR vs SI valve cover (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">I learned or.. heard recently itr valve cover is a bit taller, i know grommets are different on itr
i guess it makes no differnce, but if it does.. then.. why taller valve cover for itr vs gsr, and is it same height as civic valve cover?</TD></TR></TABLE>
The grommets are chrome on Type Rs. I don't think there is any difference except being red and black between the 3 unless you take into account the H/Honda Motor Co. and small/big DOHC VTEC.
Old Oct 28, 2005 | 12:40 PM
Jesus.'s Avatar
Default Re: GSR vs ITR vs SI valve cover (Jowee 1162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 &raquo;</TD></TR><TR><TD CLASS="quote">The grommets are chrome on Type Rs. I don't think there is any difference except being red and black between the 3 unless you take into account the H/Honda Motor Co. and small/big DOHC VTEC.</TD></TR></TABLE>
There is another difference... the type-R valve cover is actually cheaper than the GSR.
Type-R 12310-P73-A00 $199.48
GSR 12310-P61-A00 $261.35
There are actually a handful of ITR parts that are cheaper than their GSR counterparts, but none are performance related IIRC.
Old Oct 28, 2005 | 02:10 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: GSR vs ITR vs SI valve cover (NNY)
but none are performance related IIRC?
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NNY &raquo;</TD></TR><TR><TD CLASS="quote">
There are actually a handful of ITR parts that are cheaper than their GSR counterparts, . </TD></TR></TABLE> WHY
Old Oct 28, 2005 | 02:12 PM
IGGY's Avatar
Default Re: GSR vs ITR vs SI valve cover (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote"> WHY</TD></TR></TABLE>
Because.
Jowee's Avatar
Because there are more GSRs on the road than ITRs. If your valvecover is chipping and the "service advisor" says it could cause your engine to blow, you'll buy another.
If you want performance out of your valvecover, dish out $915 and get a Mugen.
Old Oct 28, 2005 | 02:14 PM
98 Spec R's Avatar
If you want performance out of your valvecover, dish out $915 and get a Mugen.</TD></TR></TABLE>
LMAO
How much power will that make?
Old Oct 28, 2005 | 02:22 PM
markpaco's Avatar
Because there are more GSRs on the road than ITRs. If your valvecover is chipping and the "service advisor" says it could cause your engine to blow, you'll buy another.</TD></TR></TABLE>
Actually cost goes down with the more you make. So the GS-R valve cover should be cheaper. I don't know the real reason why the the Type R valve cover is cheaper as it should cost more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 &raquo;</TD></TR><TR><TD CLASS="quote">If you want performance out of your valvecover, dish out $915 and get a Mugen.</TD></TR></TABLE>
The 'performance' advantage with the MUGEN is that it is lighter. However, you could take a **** and get the same 'performance' advantage for free.
Old Oct 28, 2005 | 02:30 PM
Jowee's Avatar
Default Re: GSR vs ITR vs SI valve cover (markpaco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco &raquo;</TD></TR><TR><TD CLASS="quote">
The 'performance' advantage with the MUGEN is that it is lighter. However, you could take a **** and get the same 'performance' advantage for free.</TD></TR></TABLE>
That's common sense, but Honda doesn't care how little it costs them; they're in the business for profit. Why else do you think a lip is more expensive than a front bumper? Because they're wear and tear items that people will replace after time. So if you have a higher demand for GSR valvecovers which is obvious since they greatly outnumber ITRs, you're going to milk that market regardless how much it cost you to produce the product.
The true performance aspect of the Mugen valvecover is it's internal baffling to help your engine breathe better as well as the lightweight F1 aluminum they use - :sarcasm:
Old Oct 28, 2005 | 02:50 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 &raquo;</TD></TR><TR><TD CLASS="quote"> Why else do you think a lip is more expensive than a front bumper? </TD></TR></TABLE>
My understanding is that 97 ITR front lips are no longer available (with only 480 or so 97 ITRs sold in North America).
Whereas they made tens of thousands of 94-97 Intrgras ....
Old Oct 28, 2005 | 03:01 PM
Jowee's Avatar
Default Re: GSR vs ITR vs SI valve cover (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Whereas they made tens of thousands of 94-97 Intrgras .... </TD></TR></TABLE>
Sorry sir, I should have been more specific and mentioned I was talking about Civic lips. http://www.hondaautomotivepart...UMPER
Even with 98-01 lips, they're significantly more than the front bumper.
http://www.acuraautomotivepart...y.jsp
Same thing with the front and rear bumpers. There are more rear ends than front end collisions, which is why the rear is more expensive. Plastic mold injection for the front bumper can't be that much different than a rear.
Old Oct 28, 2005 | 03:26 PM
Jesus.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">My understanding is that 97 ITR front lips are no longer available (with only 480 or so 97 ITRs sold in North America).
They are still around. You can still order the 97 ITR front lip from the offical honda e-store, and it will be shipped to your local dealership.
SPOILER, FR. AIR 71110-ST7-R00ZZ $431.36
Shipping: $35.00
Estimated Tax: $25.88
Total: $492.24
Old Oct 28, 2005 | 04:07 PM
ZygSpeed's Avatar
Good to know, I still have a brand new one I haven't mounted yet.
For better or worse at this point ....
Old Oct 28, 2005 | 04:26 PM
KOALA YUMMIES's Avatar
If you want the ultimate in performance valve covers see my sig
BTW zygspeed, if you decide you no longer want to hang onto that lip 357 could use an uncracked lip
Old Oct 28, 2005 | 04:28 PM
ZygSpeed's Avatar
Default Re: GSR vs ITR vs SI valve cover (KOALA YUMMIES)
I could use $400.
Which is pretty much what I paid for it a while back.
Just patch up your old one and repaint it .... but we digress.
Old Oct 28, 2005 | 04:31 PM
Rorz yeah, I did fix it with super glue and some touch up paint, couldnt even tell but I was a bit wreckless pulling out of the driveway one day and it re-cracked, or maybe it was the truck tire on the freeway cant rmeember
THis thread needs a pix
Old Oct 28, 2005 | 04:35 PM
RTW DC2R's Avatar
the shocker valve cover &gt; ***
Old Oct 28, 2005 | 04:38 PM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">Rorz yeah, I did fix it with super glue and some touch up paint, couldnt even tell but I was a bit wreckless pulling out of the driveway one day and it re-cracked, or maybe it was the truck tire on the freeway cant rmeember
bling blang
Old Oct 29, 2005 | 08:28 AM
veggiemaster's Avatar
There are actually a handful of ITR parts that are cheaper than their GSR counterparts, but none are performance related IIRC. </TD></TR></TABLE>
Actually, thats false. The ITR rear lower control arms are cheaper than rs/ls/gs/gsr lcas. And they are lighter. thats performance right there!
Old Oct 29, 2005 | 09:08 AM
DCnotTHEshoes's Avatar
If you were a baller ...
you would purchase the Spoon or Mugen valve covers.
[IMG][/IMG]
[IMG][/IMG]
Old Oct 30, 2005 | 07:00 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: GSR vs ITR vs SI valve cover (DCnotTHEshoes)
any one who would pay 450 for a lip is crazy
Old Oct 30, 2005 | 10:45 AM
Jowee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">any one who would pay 450 for a lip is crazy</TD></TR></TABLE>
Value is in the eye of the beholder. Some people don't think twice about spending 5-6 digit prices for modifications for their cars just because they can afford to.
Old Oct 30, 2005 | 04:49 PM
pearl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco &raquo;</TD></TR><TR><TD CLASS="quote">The 'performance' advantage with the MUGEN is that it is lighter. However, you could take a **** and get the same 'performance' advantage for free.</TD></TR></TABLE>
LOL!
Old Oct 30, 2005 | 04:55 PM
PrinceAli132's Avatar
Shipping: $35.00
Total: $492.24 </TD></TR></TABLE>
You should look into ordering from Len, a h-t sponsor. He works at a Acura dealership and gives great discounts on all parts. I got my front lip shipped to my house for like low 300's.
Ali
