Only revs to...
Old Oct 28, 2005 | 09:43 AM
6E LUDE's Avatar
Default Only revs to...
to about 6,000-6,500 rpm's when I press the gas down from idle to 6,500. When it hits that high the rpm's it won't go higher. It use to go up to 7,000 rpm's but now it won't. This is all from idle to high rpm's when im just sitting there. I haven't done anything new to my car. The only thing I fixed is the Engine Coolant Circuit Sensor. It was unplugged so I plugged it back up. Specs in sig. Please help.
Old Oct 28, 2005 | 10:25 AM
Hawkze_2.3's Avatar
Default Re: Only revs to... (6E LUDE)
Don't rev your car that high in nuetral. That's rediculous.
Old Oct 28, 2005 | 10:40 AM
The Weather Man's Avatar
Mine always goes as high as I need it to - but why rev that high in neutral anyway?
What engine management are you using?
Old Oct 28, 2005 | 11:06 AM
prelittlelude's Avatar
yeah what is your engine managment.. there is no reason to rev that high just standing still. the msd might have a rev control..
Old Oct 28, 2005 | 12:57 PM
6E LUDE's Avatar
why not rev it that high in neutral? I only did it twice and stop after that cause i dont' want to ruin the motor. Right now i have a stock ECU. I'm not sure were to look for a performance chip. LINKS?
Old Oct 28, 2005 | 01:09 PM
JG Luder's Avatar
Your car doesn't go into VTEC when it's not in gear. It has a load pressure switch.
Basically it sits in safe mode. And when it's there, the rev limiter should be 6000-6500 or something like that. I haven't tried that since... oh, I dunno, I was 16? I've never seen the point in revving the motor that high while sitting still... that is unless you're Paul Walker or Vin Diesel.
Old Oct 28, 2005 | 01:15 PM
6E LUDE's Avatar
Ok thx guys, just makin sure i don't mess my stuff up. That was my last 2 times i do that
Old Oct 28, 2005 | 01:58 PM
SteveoBA8's Avatar
Default Re: (6E LUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6E LUDE &raquo;</TD></TR><TR><TD CLASS="quote">Ok thx guys, just makin sure i don't mess my stuff up. That was my last 2 times i do that </TD></TR></TABLE>
Your bottom end will be happy now. Make sure theres a load on the engine before you try to rev that high.K
Old Oct 29, 2005 | 06:33 PM
preludedude94's Avatar
Last time I reved a car that high in neutral, I blew an apex seal . Yeah it was an RX-7 but the car won't even start now because of that. Now I realize how dumb it was because you're not impressing anybody.
Old Nov 2, 2005 | 08:56 PM
Brown-tec's Avatar
Default Re: Only revs to... (preludedude94)
well u can rev it as high as you want to in neutral......if u wanna be a ricer
Old Nov 3, 2005 | 03:16 AM
How about you slap yourself for replying to a post that is three days old.
Modified by TheKingPin at 7:20 PM 11/3/2005
Old Nov 3, 2005 | 02:15 PM
Brown-tec's Avatar
Default Re: (TheKingPin)
why the f uck would i slap myself u jack ***
Modified by Brown-tec at 2:37 PM 11/4/2005
Aponcebmx
Dec 19, 2012 08:40 AM
bazzynga
Honda Civic (2006 - 2015)
Sep 6, 2011 08:51 AM
lsturbo*
May 21, 2008 01:48 PM
blucrx
Sep 11, 2006 08:36 PM
nonv
Dec 3, 2004 08:11 AM
