oil catch can?
Old Oct 28, 2005 | 06:41 AM
BDRphaSe2's Avatar
Default oil catch can?
call me stupid but wtf is that really nessassary? maybe it is please justify this for me, cause if it does nothing why have it
Old Oct 28, 2005 | 07:04 AM
MrLude1's Avatar
Default Re: oil catch can? (BDRphaSe2)
Not SOOO necessary, just a piece of mind. At higher RPM's, you may get oil-blow-off/by that the factory re-routes back to the intake. This actually lowers your octane by mixing oil into the fuel/air mixture, especially @ VTEC. The catch-can will catch it 1st, but may never fill up w/oil on a properly tuned motor. On my 1st motor, I did the breather thing. After the swap, I noticed how oily the lil breather was, so...I'm using one because I did alot of head work, & was just added piece of mind for my new JDM motor. So, you're not stupid, because now you know.
Old Oct 28, 2005 | 07:41 AM
BDRphaSe2's Avatar
well thanks for not bein a complete *** about and now it think it can be a good thing, but if you hook the tubs from your valve cover the collecter, the normal tube that would come from intake to valve cover wouldent go to valve cover anymore? just open or what err new to this container thing hahaa
Old Oct 28, 2005 | 07:43 AM
BDRphaSe2's Avatar
another quik question are their certain brands or is all this **** homeade ive never seen these onlne until recently
Old Oct 28, 2005 | 08:50 AM
mgags7's Avatar
Default Re: oil catch can? (MrLude1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrLude1 &raquo;</TD></TR><TR><TD CLASS="quote">Not SOOO necessary, just a piece of mind. At higher RPM's, you may get oil-blow-off/by that the factory re-routes back to the intake. This actually lowers your octane by mixing oil into the fuel/air mixture, especially @ VTEC. The catch-can will catch it 1st, but may never fill up w/oil on a properly tuned motor. On my 1st motor, I did the breather thing. After the swap, I noticed how oily the lil breather was, so...I'm using one because I did alot of head work, & was just added piece of mind for my new JDM motor. So, you're not stupid, because now you know.
is that a euro-r im that i spy??
usually people also run the pcv lines to the catch can, in addition to the breather.....
Old Oct 28, 2005 | 11:32 AM
IHateJDM's Avatar
Default Re: oil catch can? (mgags7)
on mine, i just ran pcv valve to catch can to intake manifold. my breather hose is still going to my intake.
Old Oct 28, 2005 | 12:26 PM
BB6racer's Avatar
Default Re: oil catch can? (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">on mine, i just ran pcv valve to catch can to intake manifold.</TD></TR></TABLE>
me too! there are two different ways that i've heard of: the catch can goes in between the valvecover and intake, or valve cover and the intake manifold. inlinefour.com recomended placing it between the vlave cover and intake manifold, i guess it creates a better vacuum that way, i think...
Old Oct 28, 2005 | 12:39 PM
IHateJDM's Avatar
Default Re: oil catch can? (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">
me too! there are two different ways that i've heard of: </TD></TR></TABLE>
i've always figured that connecting it to the intake would benefit turbo cars more than NA cars.
Old Oct 28, 2005 | 12:49 PM
K-Spec's Avatar
is it worth the money for what it does?
you know how when you WOT on your car and hit vtec, sometimes a puff of smoke comes out the back of your exhaust...(due to fuel mixture). Does this prevent that?
and jhpusa is selling the cusco one for $140 and the description says: Keep your engine bay clean with this catch can by Cusco.
I thought this can is supposed to prevent your fuel/air mixture from lowering your octane...
Old Oct 28, 2005 | 12:53 PM
98vtec's Avatar
moderator emeritus
look like skunk2 to me
Old Oct 28, 2005 | 12:56 PM
plikit's Avatar
Default Re: oil catch can? (khalal538)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">is it worth the money for what it does?
I thought this can is supposed to prevent your fuel/air mixture from lowering your octane...</TD></TR></TABLE>
yeah im curious now too.
Old Oct 28, 2005 | 01:00 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">you know how when you WOT on your car and hit vtec, sometimes a puff of smoke comes out the back of your exhaust...(due to fuel mixture). Does this prevent that?
nope, that's fuel.
it decreases the amount of blow by gasses that are reintroduced to the intake manifold. re-burning these gasses are good for emissions, bad for your A/F ratio and power.
Old Oct 28, 2005 | 01:02 PM
BeanBag64's Avatar
Default Re: oil catch can? (plikit)
It is a skunk2
Old Oct 28, 2005 | 11:08 PM
DIRTYsouthBB6's Avatar
Originally Posted by
[img
https://i6.photobucket.com/albums/y201/MrLude1/IM000978.jpg[/img]
Your the first Prelude owner that I've seen that uses the DC Sports air intake.
But, back on topic, I three use my catch can between the intake manifold and the valve cover, while retaining the factory Honda PCV valve.
This brings me to another question: on http://www.g2ic.com, this guy was saying that the hose between the valve cover and the air intake needs to be left in tact. He said that, because of the positioning of the nipple that is on the air intake tube, that pressure is actually pushed into the crankcase, not sucked into the air intake. Is this true?
Old Oct 29, 2005 | 12:19 AM
planeman01's Avatar
its not hooked up right
the breather valve needs to be connected to a vacuum source, or tie it into your exhaust via a slash cut (search for it) to draw the fumes out of the vc....right now there's no vacuum to draw out the fumes from the vc. anyhting comming out of there is doing so on its own, not cause of your catch can
Old Oct 29, 2005 | 12:26 AM
K-Spec's Avatar
Default Re: (planeman01)
ok i'm lost, does anyone have a diagram of how this works or can they further explain to me exactly what is what?
Old Oct 29, 2005 | 06:54 AM
Default Re: (khalal538)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">ok i'm lost, does anyone have a diagram of how this works or can they further explain to me exactly what is what?</TD></TR></TABLE>
Basically it all stems from this:
In every internal-combustion engine, there is " blowby " through the piston rings. Blowby pressure builds up little by little in the motor's crankcase. This pressure has to go somewhere. If there were no source of vaccuum draw or escape, then the pressure would eventually build-up to the point that it would start causing gaskets to leak, as this would be the only place for the built-up pressure to escape from. The vehicle's PCV valve works with a source of vaccuum ( usually the intake manifold or air intake, or both ) to help draw pressure out of the crankcase via vaccuum. But remember, this pressure that is being sucked into the intake manifold and/or air intake contains oil fumes, which have three harmful side effects:
1. they lower the octane of the fuel being burned ( by lowering the octane ofthe fuel being burned, the motor is much more likely to see detonation, especially when boosted )
2. it makes the intake manifold dirty over time, as well as the intake valves
3. I had a third one in my mind but I forgot it... oh well
An oil catch can, when baffled, will trap oil from entering the intake manifold and/or air intake to be re-burned, while still allowing vaccuum to pass through it. Therefore, the necessary source of vaccuum to relieve crankcase pressure is left in tact, but the passage of oil is blocked.
Old Oct 29, 2005 | 09:20 AM
bigz187's Avatar
Default Re: (DIRTYsouthBB6)
well said....end of discussion
Old Oct 29, 2005 | 06:03 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
If there were no source of vaccuum draw or escape, then the pressure would eventually build-up to the point that it would start causing gaskets to leak, as this would be the only place for the built-up pressure to escape from. </TD></TR></TABLE>
is that where and why your oil burns when you go into vtec? because of all the pressure?
Old Oct 29, 2005 | 08:36 PM
is that where and why your oil burns when you go into vtec? because of all the pressure?</TD></TR></TABLE>
No, the oil is burned in the combustion chamber with the fuel. Some oil, especially at higher RPMs, passes through the piston rings and ends-up being burned.
Old Oct 29, 2005 | 08:41 PM
K-Spec's Avatar
thanks for the explanation, so for my setup do you recommend one?
my setup: cai/h/e w/high flow cat, pulley set, stock internals. had an ignition system, but it is currently removed.
Old Oct 31, 2005 | 05:43 PM
boostlude's Avatar
Is a breather filter alone bad?
Old Nov 1, 2005 | 01:04 AM
4LugR's Avatar
Default Re: (boostlude)
correct me if im wrong, but i think the breather goes on the valve cover where the hose usually leads back into the air intake.. not from the valve cover to the IM... thats where the PCV valve is, and thats where the catch can should be connected to...
Old Nov 1, 2005 | 09:23 AM
bigz187's Avatar
Default Re: (AEMPrelude916)
i've always heard that it is your engine needs the fresh air that is supplied from the hose that runs from your intake to your valve cover
Old Nov 1, 2005 | 09:31 AM
planeman01's Avatar
Default Re: (bigz187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigz187 &raquo;</TD></TR><TR><TD CLASS="quote">i've always heard that it is your engine needs the fresh air that is supplied from the hose that runs from your intake to your valve cover </TD></TR></TABLE>
air isn't supplied to you valve cover via the hose from the intake to the vc (i.e. the valve cover breather) Gasses are drawn OUT of the VC and back into the intake as stated before. You need a vacuum to draw out those fumes i.e. the pcv valve wich allows engine vacuum to draw those fumes out and into the intake manifold.
