96-98 Depo Fog Help
Old Oct 28, 2005 | 05:58 AM
PimpinEX's Avatar
Default 96-98 Depo Fog Help
I already posted this on ClubCivic and couldnt really get any answers, so i'll try here. I ordered the 6th gen depo fogs from passwordjdm.com, the instructions are extremely shitty and im not sure where a few of these wires go. Heres a picture of the wiring harnesses
I have no idea where this black plug goes, ive never seen anyone with this plug
This red wire extension runs through the firewall, but then where does it go to ?
any help would be appreciated, thanks alot
Old Oct 28, 2005 | 06:05 AM
Slow EJ8's Avatar
Default Re: 96-98 Depo Fog Help (PimpinEX)
lol, sry I cant really help out but for some funny captions on the pics
Old Oct 28, 2005 | 06:18 AM
slowman's Avatar
I took way too long
Default Re: 96-98 Depo Fog Help (Slow EJ8)
just plug everything in that has a mating plug and see what happens. i just installed the depo kit on my car not too long ago and it's really easy. just plug everything in logically. pm me for more questions, if you have them.
Old Oct 28, 2005 | 07:42 AM
jdmztrane's Avatar
The black plug i believe either goes to a plug behind the interior fuse panel or to the plud that is behind youre headlight. (im pretty sure its the one behind your fuse panel) The red wire with the female connector goes to the interior fuse pannel. If you got directions with the lights it should tell you what pin to put it in. Im not sure off the top of my head but i can look when i get home from work. Hope that helps some.
Old Oct 28, 2005 | 12:33 PM
PimpinEX's Avatar
Default Re: 96-98 Depo Fog Help (slowmanEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowmanEJ &raquo;</TD></TR><TR><TD CLASS="quote">just plug everything in that has a mating plug and see what happens. i just installed the depo kit on my car not too long ago and it's really easy. just plug everything in logically. pm me for more questions, if you have them.</TD></TR></TABLE>
yea, silvertuner's Depo fogs had different harnesses (pic) he didnt have the black plug and his red wires matched up... It would be really easy if mine were like that. Im still looking for both of those plugs mates.
Old Oct 28, 2005 | 07:32 PM
PimpinEX's Avatar
bump
Old Oct 28, 2005 | 09:11 PM
Undercover_Skank's Avatar
dunno....sorry..but heres a bump
Old Oct 29, 2005 | 05:30 AM
VRD^sam's Avatar
Default Re: 96-98 Depo Fog Help (Undercover_Skank)
shoulda picked some up at http://procarparts.com
Old Oct 29, 2005 | 05:45 AM
RC_Benjamin's Avatar
man those fog lights are nasty anyways, sell them and say "complete, just opened for pictures"
Old Oct 29, 2005 | 07:13 AM
PimpinEX's Avatar
Default Re: 96-98 Depo Fog Help (RS93DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS93DA &raquo;</TD></TR><TR><TD CLASS="quote">man those fog lights are nasty anyways, sell them and say "complete, just opened for pictures"</TD></TR></TABLE>
Nah, they would be pretty bad *** if i could get them wired up. Theres a brown plug taped behind the headlight for OEM fogs that DOES NOT mate with anything in my harnesses...i really want to get these put on today.
Old Oct 29, 2005 | 09:40 AM
mike1114's Avatar
The red wire goes through the firewall like you said to the fuse box, this is the accesory power. It should go to one of the male spades at the top of the fuse box, sorta like the brown plug for the switch. U can run it to one that has power when u turn the lights on so the fogs will only come on when the lights are on, or you can run it to one that has power when the key is turned to at least ACC 2.
I'm checking the pics for the other questions.
I think the black plug may be for a model year that is not yours. U probably just ignore it.
Old Oct 29, 2005 | 10:07 AM
PimpinEX's Avatar
Default Re: 96-98 Depo Fog Help (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">The red wire goes through the firewall like you said to the fuse box, this is the accesory power. It should go to one of the male spades at the top of the fuse box, sorta like the brown plug for the switch. U can run it to one that has power when u turn the lights on so the fogs will only come on when the lights are on, or you can run it to one that has power when the key is turned to at least ACC 2.
I think the black plug may be for a model year that is not yours. U probably just ignore it.</TD></TR></TABLE>
well i ran the brown plug to the one that it has power when the lights are on (didnt work anyway), but somehow these two harnesses have to connect...i cant understand it.
Old Oct 29, 2005 | 10:16 AM
mike1114's Avatar
Ok sorry. I was looking some more.....
The harness with the brown plug:
Brown plug goes to fuse box.
Black is ground
white plug goes to the back of the switch in the dash board.
Red wire goes through firewall and that is the one that connects to ther other harness.
they fucked up on this harness for some reason. the black plug that you do not know what it does it the wire that connects to the red wire from the switch harness.
Wierd, they accidently stuck a connector on it, you just have to cut it off and connect it either butt connector, solder.
Old Oct 29, 2005 | 10:19 AM
PimpinEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">Ok sorry. I was looking some more.....
Black is ground
Red wire goes through firewall and that is the one that connects to ther other harness.</TD></TR></TABLE>
yea i see exactly what you mean, its just i dont know how the red wire connects to the other harness...ive contacted passwordjdm.com, hopefully they can help me out
Old Oct 29, 2005 | 10:25 AM
mike1114's Avatar
Wierd, they accidently stuck a connector on it, you just have to cut it off and connect it either butt connector, solder.</TD></TR></TABLE>
Old Oct 29, 2005 | 12:17 PM
PinkMaggit's Avatar
lol at pics free bump
Old Oct 29, 2005 | 01:28 PM
TurboCoop's Avatar
Default Re: 96-98 Depo Fog Help (PinkMaggit)
just for future reference-- what bulbs do these fog lights use, and are they the same as the procarparts.com ones, cause they're only $80 instead of like $110???
Old Oct 29, 2005 | 02:39 PM
bebfsu1's Avatar
That really sucks. I got some esuse OEM style ones off ebay and I just installed them today. It was kind of a pain but all the wires were plug and play. I didn't need to strip or solder any wires. This thread from clubcivic may help you out...http://www.clubcivic.com/board...66852 Not exactly the same kit but maybe it can get you an answer and it has lots of pictures.
Old Oct 29, 2005 | 04:41 PM
bebfsu1's Avatar
I was thinking about it and I think I may know where it goes....Does the connector you labeled as connecting to the fusebox plug into the front of the fuse box? I know on my kit I had to plug in two plugs on the front of the fuse box and then there was also a connector I had to plug in to a connector taped with blue tape to the back of the fuse box.
Old Oct 29, 2005 | 09:45 PM
PimpinEX's Avatar
Default Re: 96-98 Depo Fog Help (TurboCoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">just for future reference-- what bulbs do these fog lights use, and are they the same as the procarparts.com ones, cause they're only $80 instead of like $110???</TD></TR></TABLE>
im pretty sure they use H1's. Yea i splurged the extra $30 just because i thought this kit would be nicer and easier to install
Old Oct 29, 2005 | 09:48 PM
PimpinEX's Avatar
Default Re: 96-98 Depo Fog Help (bebfsu1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bebfsu1 &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking about it and I think I may know where it goes....Does the connector you labeled as connecting to the fusebox plug into the front of the fuse box? I know on my kit I had to plug in two plugs on the front of the fuse box and then there was also a connector I had to plug in to a connector taped with blue tape to the back of the fuse box.</TD></TR></TABLE>
The esuse ones have two brown plugs, i only have one for the front of the fuse box. That link helped me out a few days ago, but still no black plug...
Old Oct 29, 2005 | 10:21 PM
jdmztrane's Avatar
i got an ebay kit for 35 shipped. they fit perfect and look even better with yellow glass paint on them. the kit was really easy to install with detailed instructions
Old Oct 30, 2005 | 09:08 AM
PimpinEX's Avatar
Default Re: 96-98 Depo Fog Help (jdmztrane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmztrane &raquo;</TD></TR><TR><TD CLASS="quote">i got an ebay kit for 35 shipped. they fit perfect and look even better with yellow glass paint on them. the kit was really easy to install with detailed instructions </TD></TR></TABLE>
It sucks that i payed this much for fogs thinking they would be perfect, when i could have had a set that actually works for half the price...
Old Oct 30, 2005 | 11:44 AM
TurboCoop's Avatar
Where do you get the yellow glass paint??? I know somebody told me before but I forgot and I need some, I just bought the ebay ones. Of course they're only $29.99, but shipping is $35 I hate how these ******** can do that, it doesnt cost $35 to ship it anywhere within the states.
Old Oct 30, 2005 | 07:11 PM
PimpinEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">Where do you get the yellow glass paint??? I know somebody told me before but I forgot and I need some, I just bought the ebay ones. Of course they're only $29.99, but shipping is $35 I hate how these ******** can do that, it doesnt cost $35 to ship it anywhere within the states. </TD></TR></TABLE>
search
http://www.createforless.com/p...1x061
http://www.jimmmmmmmah.com/Ins...s.htm
