Loud Tapping
Old Oct 27, 2005 | 05:44 PM
ProPerformance's Avatar
Default Loud Tapping
Have a very loud clanking noise coming from engine.I have a fully built h22a from top to bottom.Thought it could be piston rattle,but the builder say's it's not.Swaped lma's the noise went away,but as soon as I dyno'ed it came back.Can over reving engine(8300)cause new lma's to go out that fast.Also checked for bearing material in pan and it was clean.
Old Oct 27, 2005 | 05:52 PM
92bubblesi's Avatar
Default Re: Loud Tapping (ProPerformance)
What conditions makes it happen. Does it only happen when cold? Does it get louder when the engine gets hot? Is it louder under load or deceleration? Give more details.
Old Oct 27, 2005 | 06:03 PM
Default Re: Loud Tapping (92bubblesi)
Not as noticable when cold.More as car get's warmer and under a load.Car still made 448whp on 15psi and pump.Just so loud I wanna tear the whole car down.
Old Oct 27, 2005 | 06:15 PM
shamoo's Avatar
Will you make something up for me please?
Hmm, doesn't sound too good. Does the sound increase based on engine speed or wheel speed?
Old Oct 27, 2005 | 06:49 PM
Default Re: Loud Tapping (shamoo)
Sound pretty much stops after 3500 rpm.
Old Oct 27, 2005 | 07:08 PM
_BEN_'s Avatar
Sounds lame but you didn't mention it.
Have you checked your valve lash.
Old Oct 27, 2005 | 07:14 PM
mmuller's Avatar
Mad Scientist
make a sound wave or vid; if not your going to have to be a little more descriptive of where the tapping its coming from..
Default Re: Loud Tapping (_BEN_)
10 or so times.Compression and leak down test came out good.Sounds like it's coming from the upper part 2&3 cylinder (behind turbo mani).
Old Oct 28, 2005 | 06:10 AM
bump...morning
Old Oct 28, 2005 | 11:18 AM
mmuller's Avatar
Mad Scientist
Default Re: Loud Tapping (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">make a sound wave or vid; if not your going to have to be a little more descriptive of where the tapping its coming from..</TD></TR></TABLE>
regnevazota
Dec 29, 2010 10:56 AM
hisoka
Oct 17, 2007 01:31 PM
mike5809
Jul 2, 2007 12:16 AM
blackriceman
Dec 3, 2004 04:48 AM
