Torque spec on a d16 head
Old Oct 27, 2005 | 01:49 PM
coldfiremx's Avatar
Default Torque spec on a d16 head
Anyone know the torque specs for a d16y8 head, i am doing a head gasket and timing belt for a friend, and I cater mostly to Subaru/Nissan. Any help is appreciated.
Old Oct 27, 2005 | 02:02 PM
Timmay's Avatar
Default Re: Torque spec on a d16 head (coldfiremx)
i think its 22 first step then 47lbs
thats if your on stock head studs
also start from the middle and work your way out
Old Oct 27, 2005 | 02:04 PM
si0385.'s Avatar
i believe it is 22lbs the first time, than 53lbs second time around, working from the inside bolts to the outside...
but i could be wrong its been a while
Old Oct 27, 2005 | 02:05 PM
coldfiremx's Avatar
Default Re: Torque spec on a d16 head (turbodreamz0385)
Cool thanks.
Old Oct 27, 2005 | 02:07 PM
Timmay's Avatar
OEM honda manual says
14, 36 then 49
i usually go 22 then 47-49
i go 60+ on my ARP's
roger93si
Jan 16, 2007 10:12 AM
roger93si
Jan 16, 2007 02:14 AM
B18C Turbo
Oct 16, 2006 06:31 PM
Powered By Garrett
Apr 22, 2005 08:33 PM
