Boosting a single
Old Oct 27, 2005 | 12:45 PM
1badcivicchic's Avatar
Default Boosting a single
What would be a good compression for pistons on a single that is boosted....I have a D16Z6 SVTECH turbo and blew my bottom end simply due to the compression of the pistons, boost was up at 9 (technically probably boosting at high speeds around 15-20) and she got very sick..... how low should i go on my piston compression wtih my new rebuild..... any help would be VERY much appreciated!
Old Oct 27, 2005 | 12:47 PM
FalkenSiR's Avatar
Default Re: Boosting a single (1badcivicchic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badcivicchic &raquo;</TD></TR><TR><TD CLASS="quote">I have a D16Z6 SVTECH turbo and blew my bottom end simply due to the compression of the pistons </TD></TR></TABLE>
def sig material
To answer your question. There is a Forced induction section.
Archidictus's Avatar
Unceasing Measure
SVTECH, eh? You wouldn't happen to mean SOHC VTEC, now would you? Put 9.0 or 10 : 1 CR pistons in it and get a good tune and you'll be all set.
Old Oct 27, 2005 | 12:48 PM
FalkenSiR's Avatar
Default Re: Boosting a single (Archidictus)
No. Since when SVTECH = SOHC VTEC?
Old Oct 27, 2005 | 12:50 PM
Default Re: Boosting a single (fast88std)
Uh.....................yes boys...... S O C H V T E C H.......i typed out svtech so i didnt have to spell it all out, but you blew that so here i am typing it all out.....YES, a soch vtech...happy now??? And that is what I thought....Im thinking for that motor i will go with 9/1 compression. Thanks!
Old Oct 27, 2005 | 12:52 PM
VTEC..............god you all are making a tuner girl nervous! JEEZ!!!
Old Oct 27, 2005 | 12:55 PM
JDM EG Hatch's Avatar
it's spelled SOHC VTEC
Old Oct 27, 2005 | 12:57 PM
Default Re: Boosting a single (JDM EG Hatch)
Yeah.........I know I corrected myself. Thanks
Old Oct 27, 2005 | 01:01 PM
xCIVICx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">SVTECH, eh? You wouldn't happen to mean SOHC VTEC, now would you? Put 9.0 or 10 : 1 CR pistons in it and get a good tune and you'll be all set.</TD></TR></TABLE>
they come stock with 9.2:1!!!! put some JE low crompressionsin around 8.5:1 or even 8:1.
If you blew it from being stock compression before then it will happen again.
Old Oct 27, 2005 | 01:11 PM
si0385.'s Avatar
Default Re: Boosting a single (xCIVICx)
what blew in the bottom end?
it depends on how much you want to boost, cuz they are low compression motors as it is, anything less and you're gona have turbo lag
Old Oct 27, 2005 | 01:12 PM
xCIVICx's Avatar
Default Re: Boosting a single (turbodreamz0385)
turbo lag depends on the size of his turbo those. sure every turbo has lag but some you can't even tell....
what size turbo you be pushing boy?
Old Oct 27, 2005 | 01:18 PM
si0385.'s Avatar
no turbo yet i just moved to a new state and as soon as i start working im gona start on a new project car,
had a 90 civic hatch si in NY but some shmucko stole it
Old Oct 27, 2005 | 01:20 PM
xCIVICx's Avatar
lol.... i more of less ment 1badcivicchic
Old Oct 27, 2005 | 01:22 PM
si0385.'s Avatar
haha... my bad
Old Oct 27, 2005 | 01:59 PM
Kyles ej1's Avatar
SOHC my DOHC
SOCH .....CHOKE ON THAT BITCH
Old Oct 27, 2005 | 02:17 PM
dogbiscuit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badcivicchic &raquo;</TD></TR><TR><TD CLASS="quote">Uh.....................yes boys...... S O C H V T E C H.......i typed out svtech so i didnt have to spell it all out, but you blew that so here i am typing it all out.....YES, a soch vtech...happy now??? And that is what I thought....Im thinking for that motor i will go with 9/1 compression. Thanks! </TD></TR></TABLE>
No fast88std, that right there is "Signature Material."
Old Oct 28, 2005 | 09:28 AM
Default Re: Boosting a single (dogbiscuit)
Gezuz....you guys are seriously being as*es.....i misprounounced my sohc-vtec.....deal wtih it...i type fast.
I talked wtih my husband last night, and he and i decided to go wtih the lower compression pistons than 9.1......we also figured out that the whole reason it bottomed out- was like I said....there was too much boost and there was no where for the pressure to escape....I am almost ready to say F* turbos, only because everyone at the shop seems to think that going all motor is still expensive but in the long run our turbo car will require much more maintenance. Oh well...we're doing the work on it ourselves, so the rebuild on the bottom end wont be anymore than 1000-1200 even with some better internals. Anyway- thanks boys for humoring me and giving me a hard time! Have a great weekend! Check out my site onmyspace, and MY new ride.....(Fully built B18SGR)...she needs a little work, I am getting a new front bumper, rear taillights and cf hood...but other than that shes pretty damn sick
Old Oct 28, 2005 | 09:33 AM
_gurusan_'s Avatar
lower than 9:1? ....
I would stick to 9:1 c/r with some forged internals and you can daily drive at 1 bar with good tuning.
N/A isn't any more reliable....it's just more expensive and slower.
Old Oct 28, 2005 | 11:51 AM
noboostedEGo's Avatar
I'm sorry, I'm just really confused right now:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badcivicchic &raquo;</TD></TR><TR><TD CLASS="quote"> boost was up at 9 (technically probably boosting at high speeds around 15-20) </TD></TR></TABLE>
I don't know what this means. Are you saying that 15-20mph is high speed or that at high speeds you are boosting 15-20 psi?! If ur running w/no wastegate...yeah...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xCIVICx &raquo;</TD></TR><TR><TD CLASS="quote">
If you blew it from being stock compression before then it will happen again.</TD></TR></TABLE>
I think 8:1 is too low. 8.5:1 would still be okay, I think 9:1 is good. Hell, stock d16z6s can make over 200whp SAFELY w/proper tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodreamz0385 &raquo;</TD></TR><TR><TD CLASS="quote">some shmucko stole it</TD></TR></TABLE>
Congrats, you are the first person I've ever heard use that "word". Sweet.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 &raquo;</TD></TR><TR><TD CLASS="quote">SOHC my DOHC
SOCH .....CHOKE ON THAT BITCH</TD></TR></TABLE>
One of the most intelligent posts in this thread
we also figured out that the whole reason it bottomed out- was like I said....there was too much boost and there was no where for the pressure to </TD></TR></TABLE>
Wait, it bottomed out? That may not be a boost related issue. Slow down when you pull into your driveway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badcivicchic &raquo;</TD></TR><TR><TD CLASS="quote">but other than that shes pretty damn sick</TD></TR></TABLE>
Are we still talking about your car?!?
Just run 6:1 compression and be done w/it, you'll thank me later.
Old Oct 28, 2005 | 12:10 PM
pbink's Avatar
Default Re: Boosting a single (noboostedEGo)
My friend farted into a turbo once and made 4.5 psi...runnin' on pure Mexican food.
Old Oct 28, 2005 | 12:50 PM
isumase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xCIVICx &raquo;</TD></TR><TR><TD CLASS="quote">turbo lag depends on the size of his turbo those. sure every turbo has lag but some you can't even tell....
what size turbo you be pushing boy?</TD></TR></TABLE>
read a little closer and im sure youll notice that HER name on here is 1badcivicCHIC which you posted when quoting her on top of she said <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badcivicchic &raquo;</TD></TR><TR><TD CLASS="quote">VTEC..............god you all are making a tuner girl nervous! JEEZ!!! </TD></TR></TABLE>
that usuaally means girl
Old Oct 28, 2005 | 02:31 PM
m00nr0ck Si's Avatar
Default Re: Boosting a single (isumase)
Cant stop LMFAO!!!! there are several people posting in here that Im not shure if they made it through second grade! (fully built b18GRS turblow v-tech ) Damn....
Old Oct 28, 2005 | 03:10 PM
Default Re: Boosting a single (dorkoftheyear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear &raquo;</TD></TR><TR><TD CLASS="quote">Cant stop LMFAO!!!! there are several people posting in here that Im not shure if they made it through second grade! (fully built b18GRS turblow v-tech ) Damn....</TD></TR></TABLE>
No man, it was B18SGR, that's gotta be hella jdm y0! jp, its all good badasscivicbitch or whatever your name is, jk.
Oh and dont 4get to cut ur springs dawg!!
Sry im just real bored, ur all wonderful people...
Old Oct 28, 2005 | 04:22 PM
ROK801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogbiscuit &raquo;</TD></TR><TR><TD CLASS="quote">
No fast88std, that right there is "Signature Material."</TD></TR></TABLE>
done and done.
check my sig.
Old Oct 28, 2005 | 04:23 PM
FalkenSiR's Avatar
oops. Didn't realize you were a girl it's svtech baby.
