how long for coolant in block/rad to exchange?
Old Mar 7, 2002 | 04:21 PM
mr tl's Avatar
Default how long for coolant in block/rad to exchange?
weird q. after the thermostat is open, how long does it take for the coolant in the block to get to the rad, and vice versa? (obviously an estimate..)
thanks
Old Mar 7, 2002 | 06:03 PM
tinkerbell's Avatar
Default Re: how long for coolant in block/rad to exchange? (mr tl)
it depends on the RPM as the water pump is run of fthe timing belt and hence the crank...
not too long id guess... 30 seconds to 5 minutes
yes, weird Q
t..
Old Mar 8, 2002 | 08:06 PM
iceburgslim's Avatar
Is there a particular reason you would need to know the answer to this question, or is this just a pursuit of knowledge?
Old Mar 8, 2002 | 10:57 PM
mr tl's Avatar
well whenever i change the coolant, i just drain/fill the rad. i dont drain the block(for some reason every dealership i talked to does the same). so i figured in order to change all the coolant, i drain, fill the rad. let it idle for a minute or so after coolant is flowing, then drain, fill the rad again
does that make sense?
Rvu
Jan 29, 2010 08:15 AM
arrocha87
Mar 12, 2009 11:47 AM
Mr.Death
Jul 17, 2008 04:38 PM
loudassVTEC
Jan 3, 2006 02:10 PM
mikestypeRR
Nov 17, 2005 01:11 PM
