If you could build a block..
Old Oct 26, 2005 | 06:17 PM
R0ADRAG3's Avatar
Default If you could build a block..
If you could build a Z6 engine block to run boost, from scratch, what would you put in it? Pistons, sleeves, valves, springs, ect. Everyone gets that "If I had 10,000 dollars.." thought, I just wanted to hear some of those thoughts, but with this engine. Might be fun for someone that's running around HT lookin for something interresting, this might take up some time. so please post
thanks
Old Oct 26, 2005 | 06:21 PM
VRD^sam's Avatar
Default Re: If you could build a block.. (R0ADRAG3)
holly **** i didn't valves and valves spring in a block to hold more boost...**** i might have to do that....
BLOCKGUARD Homie...
Old Oct 26, 2005 | 06:30 PM
Archidictus's Avatar
Unceasing Measure
Default Re: If you could build a block.. (boosted_elf)
If I had $10,000 to burn, you couldn't pay me another couple grand to put it towards building a SOHC motor unless it had more than 7 cylinders if you catch my drift.
Old Oct 26, 2005 | 06:55 PM
JDM00SI's Avatar
Default Re: If you could build a block.. (Archidictus)
well i had 10,000 dollars
dumped it into a fully built engine and bad *** turbo set up to make over 450whp.
Old Oct 26, 2005 | 07:20 PM
Backk InTheDA's Avatar
I hate everything
Default Re: If you could build a block.. (JDM00SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">well i had 10,000 dollars
dumped it into a fully built engine and bad *** turbo set up to make over 450whp.</TD></TR></TABLE>
I'd take the B18C and build that, not this SOHC crap.
Ricerjack
Engine Machining & Assembly
Aug 17, 2016 04:08 AM
carbon fiber coupe
Sep 26, 2011 01:56 PM
No_Limits_Accord
Jan 9, 2010 09:39 AM
Running925
Jul 16, 2007 03:25 PM
