Clutch Master/Slave Cylinder Compatibility Question
Old Mar 7, 2002 | 03:06 PM
B18CJDM's Avatar
Default Clutch Master/Slave Cylinder Compatibility Question
I need to replace my clutch master cylinder and my slave cylinder on my 97' Civic DX w/ B18C. I am assuming all clutch master cylinders are the same (94-00 Integra, 92-00 Civic and 97-01 ITR) as well at the slave cylinder except for the hard line that ties into it. Is this correct are they the same part # and can they bolt right up?
Old Mar 11, 2002 | 07:12 PM
supergreenNA1's Avatar
New User
Default Re: Clutch Master/Slave Cylinder Compatibility Question (B18CJDM)
not sure... but why do you have to replace the clutch master cyl and slave cyl? just curious.. i think i might have a bad master cyl.
Old Mar 11, 2002 | 09:18 PM
MugenGTR's Avatar
Default Re: Clutch Master/Slave Cylinder Compatibility Question (supergreenSol)
i have a clutch master stage 4 in my car and shiiet! my master cylinder and/or my slave cylinder is jacked up. have no idea which one it is. but one of them is!
Old Mar 12, 2002 | 02:23 PM
B18CJDM's Avatar
Default Re: Clutch Master/Slave Cylinder Compatibility Question (MugenGTR)
When you replace them you should replace both at the same time. So nobody knows if they're compatible?
Old Mar 13, 2002 | 08:12 PM
brian g's Avatar
They are all compatible.
brian g
Old Mar 14, 2002 | 06:19 AM
H22ACiViC's Avatar
New User
Default Re: Clutch Master/Slave Cylinder Compatibility Question (brian g)
d16y8 slave cylinder will not fit on a 92-96 H22A i know that the bleeder nipple hits the front mount .. wait let me say that again it will fit on there but what is wrong is the bleeder nipple so yes it is kinda compataible.. sorry if that don't make since
Old Mar 14, 2002 | 01:43 PM
B18CJDM's Avatar
brian g
Are you positive? How do you know this, have you actually done it? Why do they have different part #'s? I do realize the slave cylinders are the same I am talking about the Clutch M/C.
[Modified by B18CJDM, 2:44 PM 3/14/2002]
Old Mar 14, 2002 | 02:29 PM
MugenGTR's Avatar
it might be different from ludes/accords as someone said before but as far as civics and integras goes, they're all the same. well, they all WORK the same at least. i have no idea if it's the same part number but i know for a fact that they will all work. i have a dc teg and i'm getting a master cylinder and a slave cylinder off my friend's wrenck eg civic.
Old Mar 15, 2002 | 07:28 PM
B18CJDM's Avatar
So you haven't actually installed it yet? Let me know when you get it on and if it actually fits w/ no modification.
siregcivic
Oct 16, 2005 07:55 PM
cyrock
Jul 20, 2005 06:25 AM
acuracy r
Jul 13, 2005 06:15 AM
