99 si b16a2 about to do motor work need advice
Old Oct 26, 2005 | 04:01 PM
choad69's Avatar
Default 99 si b16a2 about to do motor work need advice
i have a 99 si
i am about to do:
8:5 JE piston heads
4340 rods
deck the head
super tech valves
crower dual valve spring
arp head studs
clutch master stage 3 clutch
run the stock gasket and cams (don't know if i should i was just told that was best)
skunk 2 intake manifold
i am trying to decide between the greddy profect boost controller or a stand alone system (do not know which system is best though)
a drag-rev hard stage 2 turbo (i want to run a turbonectics ???)
i need advice on anything else that i need to have and on the stuff i have desided on and if 550cc or 650cc is better and which fuel pump is best to run
also i need axles so which will that the power
i want to run 20-22psi through the motor and off of 93 octane
i want a daily driver at maybe over 350hp i want 400hp
but i do no think that will happen idk
anyway if anyone has any ideas or they have used or have had someone they now used any of the stuff hit me back
you can email me fast at carl.manley@langley.af.mil
or call at 757-927-8784
thanks
I Quarantined I
Jan 5, 2009 08:22 PM
I Quarantined I
Dec 31, 2008 04:24 PM
choad69
Oct 26, 2005 04:59 PM
Obie
22
Oct 8, 2003 09:30 AM
