jdm 1 piece headlight
Old Oct 26, 2005 | 02:43 PM
BDRphaSe2's Avatar
Default jdm 1 piece headlight
hi looking into buying the jdm 1 piece black housing headlights from password jdm, goin into my usdm 4th gen ('94) with the harness and bulbs, is it just takr out old ones and drop in new ones or more **** to do, just wonderin thanks guys
Old Oct 26, 2005 | 02:49 PM
cfran55's Avatar
Default Re: jdm 1 piece headlight (BDRphaSe2)
more shizz to dooo
Old Oct 26, 2005 | 03:06 PM
BDRphaSe2's Avatar
lol thanks more **** to do but what exactly, can anyone elaborate this task
Old Oct 26, 2005 | 03:09 PM
Jordans95si's Avatar
Default Re: (BDRphaSe2)
have to use a diff. harness and junk, im not real educated on this, but im would like some in the near future....so i'll listen in for the answer
Old Oct 26, 2005 | 03:12 PM
BDRphaSe2's Avatar
http://passwordjdm.com/product...D=201
look at that site the "Complete - JDM BB4 '92-'96 Prelude 1 pc Headlights (Black)" is what im interested in buying.. comes with housing bulbs sockets and wiring, now will this setup just drop into my 94 si or more mods needed, plz just dont say more mods unless you know what they are and can explain or if you know a good diy site that can explain thanks!
Old Oct 26, 2005 | 04:00 PM
rawNArsxS's Avatar
if ur headlights already came with the bulbs n wires then just cut n splice the wires thats wut i did n it works fine
Old Oct 26, 2005 | 05:08 PM
94Vtecluder's Avatar
Default Re: (rawNAprelude)
It's a whole process. You have to drop off your front bumper, and fender. Remove the old headlights. Then since the JDM headlights use H1/H4 bulbs instead of USDM ones which use 9007/6 bulbs you will have to cut and rewire H1/H4 sockets your light harnesses. Then install the new headlights, bulbs, front fender/bumper and viola.
http://absoluteprelude.com/for...ID=45
There is a complete walkthru on what you need to do. It really is pretty easy too. I'm an idiot and I did it.
Old Oct 26, 2005 | 05:16 PM
ThE PiMpiN Co's Avatar
Default Re: (94Vtecluder)
You shouldn't have to remove your fender to install the headlights. You do have to rewire your headlights.
Old Oct 26, 2005 | 05:31 PM
mnlude's Avatar
Default Re: (aRaBiAn RiCe)
Yeah, removing the fenders aren't neccesary. Removing the front bumper is enough. As for the sockets, if you can't make your own, AutoZone has some for like $3. That's only the H4 harness though. I've already hooked up my H4 bulbs, but cant figure out how to hook up my H1's. Any advice? I drive through the dark with only low beams and it's scary...
Old Oct 26, 2005 | 07:26 PM
Default Re: (mnlude)
Removing the front fender makes live a whole lot easier. And I mean geez it's only 2 more 12mm bolts!
Old Oct 26, 2005 | 07:36 PM
PhazedSI's Avatar
Remove front bumper and dont forget also front bumper support. No need to remove fenders!
Old Oct 26, 2005 | 07:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mnlude &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, removing the fenders aren't neccesary. Removing the front bumper is enough. As for the sockets, if you can't make your own, AutoZone has some for like $3. That's only the H4 harness though. I've already hooked up my H4 bulbs, but cant figure out how to hook up my H1's. Any advice? I drive through the dark with only low beams and it's scary... </TD></TR></TABLE>
You messed up on your wiring then. That can be the only reason. The H4 bulb actually has two settings hi/low. From what I hear the low beam spots are day time running lights in Japan, and the high beam socket is a hi/lo beam bulb that changes (That's why H4's have a 3rd prong). Regardless check the lines, if they're getting power then ur wiring is messed up.
Old Oct 26, 2005 | 07:45 PM
Default Re: (PhazedSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhazedSI &raquo;</TD></TR><TR><TD CLASS="quote">Remove front bumper and dont forget also front bumper support. No need to remove fenders!</TD></TR></TABLE>
Ya that's what I meant.
Old Oct 26, 2005 | 08:17 PM
rawNArsxS's Avatar
yea theres no need to take the fenders off wutsoever
Old Nov 9, 2005 | 08:54 AM
mnlude's Avatar
I get that...but what i don't get is that the H1 bulb only has one prong in the back. How am i suppose to hook that up?
Old Nov 9, 2005 | 08:57 AM
mgags7's Avatar
thats wrong....there should be more than 1 prong....
Old Nov 9, 2005 | 09:16 AM
mnlude's Avatar
Default Re: (mgags7)
the h1 bulb that came with the light only has one prong. Even at Autozone, the h1 bulb they sell only has one prong. am i using the wrong one? Where can i find some?
Old Nov 9, 2005 | 12:54 PM
Jos3ph's Avatar
The H1 bulb does have one prong, but there is an H1 bulb connector socket that you put the H1 bulb in and it converts it to two prongs. I ordered some JDM headlights (just installed them a couple of minutes ago by the way) from passwordjdm last week and it came with the H1 bulb connectors sockets (one for each headlight). You can also buy them from the Honda dealership but they kinda charge alot for them.
Old Nov 9, 2005 | 04:45 PM
wstef's Avatar
Default Re: (Mnlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jos3ph &raquo;</TD></TR><TR><TD CLASS="quote">The H1 bulb does have one prong, but there is an H1 bulb connector socket that you put the H1 bulb in and it converts it to two prongs. I ordered some JDM headlights (just installed them a couple of minutes ago by the way) from passwordjdm last week and it came with the H1 bulb connectors sockets (one for each headlight). You can also buy them from the Honda dealership but they kinda charge alot for them. </TD></TR></TABLE>
Exactly. With the connector socket you should have a rubber sealing (same as for low beam bulbs. Only connector socket + rubber sealing provides the water or humidity will not enter to headlamp.
If you would not find them, contact me, I have some spare connectors and rubber sealings coming from JDM headlamps here.
Old Nov 9, 2005 | 04:52 PM
mnlude's Avatar
Default Re: (wstef)
Yeah, hit me up. How much are looking to sell them for? I don't want to drive in the snow at night without high beams. email me...
distronic
Jun 19, 2007 05:44 AM
lowered94accord
May 17, 2006 03:32 PM
s2000 mf
Nov 26, 2004 11:19 AM
92nb
Jul 28, 2004 12:50 AM
Accord_Kid
Jun 17, 2004 02:33 PM
