What cams should i use???
Old Oct 26, 2005 | 02:03 PM
singhtyper's Avatar
Default What cams should i use???
Setup is...
B18c5 block
bored out to 2.0 liter w/ ductile iron sleeves
84mm pistons
13:1 compress.
CR Forged pistons
Forged Rods
OEM main bearings
OEM rod bearings
OEM thrust washers
micropolished crankshaft
hot tanked and finish hone fully balanced and blueprinted.
P73 Itr Head
Toda valvesprings
skunk 2 retainers
so i need to know the rest..
also running hondata s100 w/p28 ecu
Help me out please...
thinking about running skunk2 Pro series (1) cams.
Old Oct 26, 2005 | 02:45 PM
Circuit Star-29's Avatar
Default Re: What cams should i use??? (singhtyper)
seems that your setup is very similar to alot of engines....
Search
Old Oct 26, 2005 | 02:57 PM
TypeRPaul's Avatar
where do u want to make the power?
Old Oct 26, 2005 | 05:29 PM
92TypeR's Avatar
FSAE
Default Re: (TypeRPaul)
Setup is very similar to mine, a tad bit higher compression.
The Skunk2 Pro2's would be my choice.
Old Oct 27, 2005 | 06:56 AM
Black R's Avatar
25 Year Member
jun 3's, skunk pro series, etc...
Old Oct 27, 2005 | 07:28 AM
xjohnx's Avatar
Toda Spec C's loooove them some high compression.
Old Oct 27, 2005 | 08:19 AM
1turbodc2's Avatar
def. stage 2 cams, u need something with a lot more agressive lift to compliment your 13to1 compression on the bottom end.
Old Oct 27, 2005 | 08:30 AM
singhtyper's Avatar
Default Re: (gssr)
thanx for all ur input i think ill try the skunk2 stage 2s and by the way do u all know anyone selling these for a good price?
Old Oct 27, 2005 | 08:54 AM
chad's Avatar
Moderator
have heard that using 2 sohc vtec cams is the best na method of power
Old Oct 27, 2005 | 09:01 AM
Slick GS-R's Avatar
Default Re: What cams should i use??? (chad)
You should post this over in the All Motor forum.
Actually, just PM tbone!
---SPEED-DEMON---
Jan 17, 2009 10:36 PM
boostd ls
Aug 9, 2006 05:28 PM
MI4$DC5
Mar 10, 2005 04:34 PM
Witty
10
Aug 8, 2003 01:52 PM
vtecjj
Dec 19, 2002 12:15 PM
