crank case relief from oil pan?
Old Oct 26, 2005 | 01:46 PM
h22 civic's Avatar
Default crank case relief from oil pan?
thinking bout tapping 2 lines into my oil pan and running them up high into a breather tank to releive crankcase presure ,what do ya think anyone try it
Old Oct 26, 2005 | 02:36 PM
thad
Guest
Posts: n/a
Default Re: crank case relief from oil pan? (h22 civic)
i dunno man, excess crank case pressure is on it's way up any way, what's your objection to tapping another valve cover releif, or a catch can?
Old Oct 26, 2005 | 04:21 PM
h22 civic's Avatar
Default Re: crank case relief from oil pan? (thad)
well its on a hseries wich is a little dif from a b series as far as relief i already have the the head releif just looking to relif the bottom of the motor without tapping the block
Old Oct 27, 2005 | 01:52 PM
h22 civic's Avatar
hmmmmm
Old Oct 27, 2005 | 04:11 PM
IN VTEC's Avatar
Default Re: (h22 civic)
It might be at or below the oil level.
Old Oct 27, 2005 | 04:15 PM
mmuller's Avatar
Mad Scientist
Default Re: (IN VTEC)
i would say tap the block
Old Oct 28, 2005 | 04:28 AM
JimBlake's Avatar
Default Re: (mmuller)
What about the passageways where oil drains back down. Aren't those big enough to equalize pressure between the crankcase & the head?
Old Oct 28, 2005 | 10:09 AM
h22 civic's Avatar
Default Re: (JimBlake)
from what i understand the 95 block dont have that passage way like the b series
Old Oct 29, 2005 | 12:33 PM
thad
Guest
Posts: n/a
maybe you could tap the freeze plugs
Old Oct 29, 2005 | 02:38 PM
h22 civic's Avatar
Default Re: (thad)
i was talking to larry at endyne he said that he taps the back of the block but the motor needs to be apart i dont see why the pan wont work if i tap pan high and run the line over the top of motor to a catch can
Old Oct 29, 2005 | 04:06 PM
DxTrix's Avatar
Not trying to jack your thread but we seem to be haveing alot of presure in our block and it has no place to go besides out the dipstick tube. Where else on a H block can you tap to reduce that presure? This is how ours is set up
Old Oct 29, 2005 | 06:40 PM
d16dcoe45's Avatar
Default Re: (DxTrix)
On all motors--the head and crankcase are connected for pressure via passages. I would not tap the oil pan simply because in a corner or acceleration, oil will come up the lines coming out of the pan. Do what they do on B-series and get the fittings for the back of the block--if you can't do that--weld some fittings to the Valvecover--and baffle in front of them--run lines from that to a catch can.
Surftouch
Nov 29, 2005 04:38 PM
failed
Nov 11, 2005 11:47 AM
h22 civic
Jan 24, 2005 12:31 PM
euclid
Nov 29, 2004 04:48 PM
fourthgenhatchB17
Apr 13, 2004 08:32 PM
