throttle cable issues.
Old Oct 26, 2005 | 09:56 AM
gunnis's Avatar
Default throttle cable issues.
Hey all,
so i swapped a b18c-r into my 93 ej1.maybe i'm giving this ******* throttle cable to much thought but regardless.
i had a brand new b18c5 throttle cable and tried to use it. it seems as if it had a slight bit of slack, like it was to long. but it worked.
so i picked up a 94-97 DOHC del sol vtec cable. and the end that connects to my pedal looks nothing like the stock d16z6 or b18 cable. see pic 1
heres all 3 cables.
and the throttle rotor end of them.
again the ITR cable i have can work i was just wondering if there is a better fit. or if i in fact have the right del slo cable.
THanx for the help
Edit: here is the ITR cabled rigged up with ai beleive a d series bracket. I adjusted it the best i could and this seems to be the ebst so far, still wondering your thoughts...
Modified by gunnis at 2:57 PM 10/26/2005
Old Oct 26, 2005 | 10:40 AM
O RLY's Avatar
Default Re: throttle cable issues. (gunnis)
Interesting thread, but I don't have the answer. In fact, I have another question. For those of you who are running an EG Coupe/Hatch, which throttle cable do you use for the H22 swap. The prelude throttle cable, or the Civic one. Sorry I didn't answer your question, and added one of my own.
Old Oct 26, 2005 | 12:03 PM
philosofy1's Avatar
forget using different cables. jdmshit.com has a bracket that allows you to use your dseries cable w/ no problem. it's like $15
Old Oct 26, 2005 | 12:19 PM
gunnis's Avatar
Default Re: throttle cable issues. (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">forget using different cables. jdmshit.com has a bracket that allows you to use your dseries cable w/ no problem. it's like $15</TD></TR></TABLE>
could have been used before but no good now really, i will just be throwing money away. plus it would about 20-25$ exchanged to canadian. plus shipping. plus duty at the border.not worth it when it i have a cable already that will work with some thought.
ok here is the pedal assem. for a 96 del sol vtec (b series i beleive) the throttle cable number does not match the sol cable I have. i checked the single came vtec and it does not match either.
http://www.hondaautomotivepart...PEDAL
My mystery cables part number is # 17880
Old Oct 27, 2005 | 10:56 AM
gunnis's Avatar
ttt
anybody know what throttle cable i have?
searching hondaautomotiveparts.com for the part numbers brings up a whole bunch of unclickable throttle cables.
none of them match the part number i have.
kelviiv
May 20, 2010 05:36 PM
spgcuantik
Mar 22, 2008 02:56 AM
bbrian
Jul 25, 2005 04:08 PM
