16x7.5 45 offset 215/45/16 tires, fit? or no?
Old Oct 26, 2005 | 09:48 AM
zc911's Avatar
Default 16x7.5 45 offset 215/45/16 tires, fit? or no?
http://www.aj-racing.com/catal...age=1
Would these fit a 98 R? Suspension is gonna be koni yellows on stock springs, for now and GC coil overs later. It will not be dropped much at all. I was even jsut hinking of ordering some higher rate springs but stock legnth so no drop. I also will have my ATS 4.929 FD tranny in come spring.
What do you guys think? Fit or not?
Old Oct 26, 2005 | 10:12 AM
LUCKY CHARMS's Avatar
Default Re: 16x7.5 45 offset 215/45/16 tires, fit? or no? (zc911)
the recomended offset range for that size tyre is 39-40.8
think you might have probs with 215 tyres
Old Oct 26, 2005 | 10:23 AM
Black R's Avatar
25 Year Member
Default Re: 16x7.5 45 offset 215/45/16 tires, fit? or no? (KISS ME LUCKY CHARMS)
no problems. It's literally 1/8" difference.....
Old Oct 26, 2005 | 10:34 AM
zc911's Avatar
Default Re: 16x7.5 45 offset 215/45/16 tires, fit? or no? (Black R)
so worse case some 5mm spacers then?
Also what would the widest tire be that you could squezze under the R on that rim?
With or without the 5mm spacer.
Also how bad will it be the the 4.40FD?
Old Oct 26, 2005 | 11:07 AM
Black R's Avatar
25 Year Member
215/45/15 is the oem tire size in japan.
it's fine... really.
225's will require a 5mm spacer - if that.
It really depends on how far you're lowered.
16x8's definitely require a spacer with 225's if you've got a +50 offset.
Old Oct 26, 2005 | 11:23 AM
zc911's Avatar
Default Re: (Black R)
great thanks
Now to get rid of my 4 bolt 16inch spoons lol
1sick740
Mar 16, 2013 11:20 PM
jew
Sep 7, 2005 10:09 AM
Phase2
Apr 30, 2003 05:49 PM
RTW DC2R
Feb 3, 2003 08:54 PM
Mr. Vapor
Jun 6, 2002 07:36 PM
