Trouble shifting into first
Old Oct 26, 2005 | 09:26 AM
EJ8chu's Avatar
Default Trouble shifting into first
as the title say sometime my car has trouble shifting from neutral to first gear after driving it...for examle if i drive then put it in neutral for a stop light then try to put it into first it sometimes doesnt want to go in easily.....im wondering wtf the problem is...thanks fo rthe help in advance
Old Oct 26, 2005 | 09:42 AM
EFz6er's Avatar
Default Re: Trouble shifting into first (xxsteve803xx)
try going from 2nd to 1st.....are you rolling when you try to put it in 1st?
Old Oct 26, 2005 | 09:55 AM
be.twenty's Avatar
blip the gas then try to pop it into first.... if you still have problems, pop it into second, blip the gas then try into first
Old Oct 26, 2005 | 11:13 AM
95lstegman's Avatar
Default Re: (da_truf)
lots of times the synchros on first and second get turned to trash by people slamming gears and also those who try to shift into first while moving a lot. and then there are those who like to shift without using the clutch . . . VERY FEW people on earth can get away with this, so don't do it! the shift collar also gets pretty abused, although the 1-2 holds up fairly well due to larger size than 3-4 or 5-R.
it could also be worn clutch/pressure plate/flywheel. sounds to me like this is the ticket. lots of times a worn clutch disc or PP or flywheel will cause hard shifting such as you describe. thankfully, clutches are cheap, if not easy to replace. get the flywheel resurfaced while you're in there.
Old Oct 26, 2005 | 02:27 PM
HONDA RR's Avatar
Could be the gear bearings.
Old Oct 26, 2005 | 05:06 PM
95lstegman's Avatar
Default Re: Trouble shifting into first (HONDA RR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA RR &raquo;</TD></TR><TR><TD CLASS="quote">Could be the gear bearings.</TD></TR></TABLE>
hehe. gear bearings? is that a total WAG or what?
Old Oct 26, 2005 | 06:49 PM
Hoonty's Avatar
It's because there is no synchro on first gear. You should only shift into first while you are 100% stopped. otherwise you will mess up your tranny.
Old Oct 27, 2005 | 05:32 AM
95lstegman's Avatar
Default Re: (Hoonty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoonty &raquo;</TD></TR><TR><TD CLASS="quote">It's because there is no synchro on first gear. You should only shift into first while you are 100% stopped. otherwise you will mess up your tranny.</TD></TR></TABLE>
i'm guessing you've never taken apart a transmission, either. yes, first gear has a synchronizer ring, just like every other gear including reverse.
Ef4doorwagon
Nov 28, 2014 10:17 PM
ateeb786
Nov 6, 2006 07:15 PM
soon2bdropped
Jun 15, 2005 09:56 PM
B-Hatchie
Oct 2, 2004 12:52 PM
tac379
17
Aug 18, 2003 06:17 PM
