trans grinds???
ok i have a 90 DA with a gsr motor and S1 trans...ive got a stage 3 exedy clutch and a lightened flywheel.... everytime im at a high RPM either upshifting or downshifting into 3rd it grinds a bit...also does this going into reverse....whast my problem??
thanks
thanks
I hate everything
It sounds like your syncro's might be going in the higher gear, i actually read a thread about this early this morning, check this out...
https://honda-tech.com/zerothread?id=1414856
I have the same problem with reverse on my daily driver DA. Try putting it into 4th then going into reverse. Works everytime for me. Otherwise reverse grinds.
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">I have the same problem with reverse on my daily driver DA. Try putting it into 4th then going into reverse. Works everytime for me. Otherwise reverse grinds.</TD></TR></TABLE>
Yeah, or putting it into 1st, then into reverse, that's just a Honda thing though.
yup, third gear may have bad synchro and usually an almost totally worn out 3-4 shift collar. your reverse problem is probably the 5-R shift collar. both collars are very common wear items. you're looking at about $300 in parts, new.
Unidentified
May 29, 2006 10:55 AM
