Small addt'l parts when doing t-belt w/pump etc? (98 DX 3-Dr Auto)
Old Oct 26, 2005 | 07:47 AM
from_zer0's Avatar
Default Small addt'l parts when doing t-belt w/pump etc? (98 DX 3-Dr Auto)
Searched, read some posts, have a good idea what i need here, however, i want to make sure i'm not missing any gaskets, seals or other incidentals in order to get the job done properly, as i'm ordering from hondaautomotiveparts.com and everything is piece-by-piece...i have:
Timing belt: Product #: 18203
Cost: $ 23.23
Water Pump: Product #: 19950
Cost: $ 61.29
O-ring (pump) Product#: 19951
Cost: $ 2.41
T-Stat Product #: 19953
Cost: $ 11.94
A/C Belt Product#: 20102
Cost: $ 8.42
Alt. Belt Product#: 20361
Cost: $ 6.99
P/S Belt Product#: 20125
Cost: $ 7.34
Does that list appear to be missing anything of importance? I know i've hit the major parts, (unless someone notices otherwise!?) so i'm just making sure i don't order all this, have the car apart and realize, '****, i need a $2 washer/gasket/cover, etc,' and end up screwed w/out even getting to enjoy it
TIA H-T'ers!
Old Oct 26, 2005 | 07:53 AM
littlegreenb18's Avatar
Default Re: Small addt'l parts when doing t-belt w/pump etc? (from_zer0)
you might want to replace your tensioner also depending on your milage. the bearing in it can go after awhile. its not essential, but it looks like you wanna get it all outta the way at once, so it might be a good idea
Old Oct 26, 2005 | 08:40 AM
Backk InTheDA's Avatar
I hate everything
Default Re: Small addt'l parts when doing t-belt w/pump etc? (littlegreenb18)
Yeah, you already stated, but change the gaskets that go along w/ that, cam seals, crank case etc..
You pretty much covered it though.
Old Oct 26, 2005 | 12:02 PM
from_zer0's Avatar
Default Re: Small addt'l parts when doing t-belt w/pump etc? (BuilttB18C5)
Thanks for the replies so far!
Anyone else w/anything else?
Old Oct 26, 2005 | 12:04 PM
gftgrill's Avatar
cap, rotor, plugs, wires, fuel filter. and don't forget coolant, oil, and filter.
not related, but if you're already doing a tune up, might as well go all the way.
B3Dr
Jan 6, 2008 10:24 AM
reno96teg
Apr 25, 2006 05:06 AM
98LS4dr
Feb 1, 2005 11:36 AM
Eluder200K
Jan 27, 2003 09:00 AM
ShiftDown
Jul 21, 2002 03:01 PM
