si cluster in eg
Old Oct 26, 2005 | 06:20 AM
sheBangZ's Avatar
Default si cluster in eg
i have a 99 cluster that came with the motor. would it fit in my eg? i used the search feuture and came up with nothing. any help would be appreciated.
Old Oct 26, 2005 | 06:30 AM
MikeEM1's Avatar
Default Re: si cluster in eg (sheBangZ)
its not going to fit
Old Oct 26, 2005 | 06:31 AM
sheBangZ's Avatar
I'm sure if people can put a gsr cluster in there, there has to be some way to put a si cluster into a eg.
Old Oct 26, 2005 | 06:34 AM
MikeEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheBangZ &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure if people can put a gsr cluster in there, there has to be some way to put a si cluster into a eg. </TD></TR></TABLE>
gsr cluster is a different shape from the Si cluster
Old Oct 26, 2005 | 06:39 AM
MikeEM1's Avatar
Default Re: si cluster in eg (MikeEM1)
just get a sir cluster
Old Oct 26, 2005 | 08:55 AM
i5olated's Avatar
it will fit with lots of modifying ive seen it done but its not worth the hassle i say just sell it and get a sir cluster if u dont mind the kmh
Old Oct 26, 2005 | 09:20 AM
resol's Avatar
Default Re: si cluster in eg (delsol4door)
or you can buy my 93 si cluster for 100 and i will bring it down there for you
Old Oct 26, 2005 | 09:41 AM
sheBangZ's Avatar
pm me you rnumber and I'll get back to you. how many miles are on it?
Old Oct 26, 2005 | 01:28 PM
o5mar1's Avatar
the miles dont matter you can take the cluster apart and roll the millage back and forth to match your current one
Old Oct 26, 2005 | 02:02 PM
FullJDMEg's Avatar
***disclaimer*** im i am not responsible if you mess up your cluster!
well to start, you have to have the following:
92-95 EX (auto or manual) gauge cluster....
99 SI gauge cluster
good soldering iron
solder
phillips screwdriver
hot glue gun
and a dremel
scissors
wire (18gauge)
when you have all those then you can start!
1. first you gotta take out your 92-95 gauge cluster. to do it you gotta undue the 2 phillips screws on the underside of the gauge cluster bezel. pry the corner of the hazard swtich so you dont scratch up anything. theres another phillips screw there. after the screws are taking out, pull gently again to remove the complete bezel/heater vent trim.unplug the clock harness. now your done with that part.
2. to take out the cluster, just unscrew the 4 phillips screws and unplug each harness.
3. taking apart the cluster.... on the trip odometer reset stick, pull the on it alittle and a part of it will come off. now go around the cluster and press all the black tabs in so you can take the front of the cluster off. now, pull very hard and be very carefully remove the needles from each gauge. from here, flip the cluster over and unscrew each gauge and untwist all bulbs. make a note of where the screws and bulbs go. put aside the gauges for now. carefully remove the then circut board. at this point your cluster should be empty. now move on to the 99 si gauge cluster! all you need to do here is take the front cover off. and pull very hard on the needles to remove them. be VERY careful!!! i used my fingernails and it hurts like a motherf**ker but it worked. after removing all the needles, flip over the cluster and unscrew the gauge from cluster housing. take a small phillips screwdrive and unscrew each face. back to the 92-95 gauges....do the samething and unscrew each face of the gauges. all you do now is put the 99si face on the 92-95 gauges (tach and speedo only). so when putting the tach and speedo back in, all you do is trim the face little by little to make the gauge fit in the cluster. just be careful not to cut away too much. now onto the the harder one - temp gauge and fuel gauge. this one you have to do a whole lot of trimming! on the 92-95 temp/fuel gauge youll notice a big clear thick plastic piece. lay the 99si temp/fuel face on it and screw it down. now try and put in in the cluster now and youlll notice that the it wont fit cause that big plastic piece is in the way. trim to it fits good. now when you try to screw the gauge back to the cluster housing the lholes for the screw wont line up. yep..you got to cut a huge chuck off the back housing. trim away till it fits! now start assembling the cluster again. start by putting the circuit board back in, then scew in the tach and the speedo. the fuel/temp you kinda just lay in there and put the front over on so it holds the temp/fuel gauge in place. move it around tell gets centered properly. now all you do is turn it over and put a little hot glue on it to hold it in its place. this part is really hard to explain how to do so ill insert a pic tonight. temp/fuel gauge to be continued!
4. i painted all my bulbs orange with transparent orange from the hobby store to give it a little more amber look to it. put all the bulbs back in except the check engine light.
so ok lets say the cluster is all modded now. take the front off again!
5. before you can put the needles back on...plug the cluster back in and crank the car up! my car always idles at 800 so i stuck it at 800 (i just purchases the new vafc2 and the tach seems to be dead on). now stick the needle on the speedo and have a friend follow you on the freeway and have him go 60 and you get side by side with him so youll know youre going 60 too and put the needle at 60. there those t2 are done. now with the fuel gauge. just go fill up your tank and put the needle at full. for the temp. make sure your car has cooled down for a few hours. turn the car on but do not crank it over yet.with the cars accessories on put the needle back at its lowest setting. now crank the car up and let it warm up. it should go to where it normally goes. now yo have to relocate the check engine light. on the plug that plus into the cluster....look for the check engine wires and run some wires to your dash and get a led light from radio shack on install the led on your dash. and the reason for relocating the check engine light is cause the temp/fuel gauge covers up the existing check engine light.
DAMN...alot of modding just to get it this way huh? some of you might think its crazy and too much time to do it. my car was at the shop getting resprayed and wasnt gonna be able to drive it for a month or so. if you think its a waste of money to tear apart a 99si guage cluster... i didnt care cause it was from my 99 hatch. well there you guys go! ill edit it with pics when i have time today. im sure theres other ways to this...but this is the way i did it. have fun!
Old Oct 26, 2005 | 02:04 PM
FullJDMEg's Avatar
that came from "DXTurbo" hit him up he stated the above
Old Oct 27, 2005 | 12:10 PM
MikeEM1's Avatar
Default Re: (FullJDMEg)
just trade your si cluster for a gsr cluster. pretty much the same redline...
Yei Leng Yang
Mar 15, 2016 08:14 PM
akarooster
Aug 24, 2012 07:05 AM
sh!ft
Jun 19, 2010 01:20 AM
B16EJ
Oct 14, 2004 01:27 PM
