My Muffler shakes badly sometime when my car is at idle
Old Oct 26, 2005 | 12:37 AM
fongph's Avatar
* B A N N E D *
Default My Muffler shakes badly sometime when my car is at idle
Not all the time, but sometime when I come to a full stop, I kind of feel that my car around the header shakes a little bit and I can feel it from the steering wheel and the shifter. I can also see my muffler is shaking back and forth in horizontal direction. Can that be a bad motor mount or? Please advice.
Thanks
Old Oct 26, 2005 | 06:32 AM
raver01x's Avatar
im not sure bout the header but my muffler shook real bad too i took it to a muffler shop and they welded a bracket on to brace it better hope that helps
Old Oct 26, 2005 | 07:44 AM
Slow EJ8's Avatar
Default Re: My Muffler shakes badly sometime when my car is at idle (fongph)
Look under your car to see if the rubber hangers holder things are all there and not loose or busted. If they are replace them. Also you shifter may be in contect with the exhaust pipe, check that it has proper clearance there.
PS. what kind of exhaust is it?
Hope some of this helps.
Old Oct 26, 2005 | 07:47 AM
jdm_sir2's Avatar
I dought it could be a hanger because at idle the engine doesn't shake like he says it does so probably the issue could be a bad mount I have that problem with my car i had torn up the upper driver side mount cause by too much wheel hop my your rear mount is the culprit! check it out!
Old Oct 26, 2005 | 07:52 AM
Slow EJ8's Avatar
Default Re: (jdm_sir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_sir2 &raquo;</TD></TR><TR><TD CLASS="quote">I dought it could be a hanger because at idle the engine doesn't shake like he says it does so probably the issue could be a bad mount I have that problem with my car i had torn up the upper driver side mount cause by too much wheel hop my your rear mount is the culprit! check it out!</TD></TR></TABLE>
FYI- the "." is your friend. Using them makes your posts much easier to read and understand.
And yes it could be a motor mount, or rubber hangers, or many other things. You say "the engine doesn't shake like he says it does", how do you know, you calling him a liar?
Old Oct 26, 2005 | 08:52 AM
fongph's Avatar
* B A N N E D *
Default Re: My Muffler shakes badly sometime when my car is at idle (Slow EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">PS. what kind of exhaust is it?</TD></TR></TABLE>
RSR EXMAG... I don't have that problem or not that obvious before I switch to RSR EXMAG from OEM....
Please help..!
Old Oct 26, 2005 | 08:57 AM
Slow EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fongph &raquo;</TD></TR><TR><TD CLASS="quote">RSR EXMAG... I don't have that problem or not that obvious before I switch to RSR EXMAG from OEM....
Please help..!</TD></TR></TABLE>
Very nice exhuast, one of my favs. Have you checked/inspected the motor mounts or rubber hangers for tearing or damage?
Old Oct 26, 2005 | 08:59 PM
fongph's Avatar
* B A N N E D *
Very nice exhuast, one of my favs. Have you checked/inspected the motor mounts or rubber hangers for tearing or damage? </TD></TR></TABLE>
rubber hangers seem fine but how can I inspect the motor mounts?
RiskyKidd
Oct 17, 2014 06:01 AM
immajackuup
15
May 8, 2008 06:59 PM
krazy one
May 7, 2006 11:41 PM
mv10s
Mar 30, 2004 08:59 PM
jabroni95gsr
Feb 19, 2003 08:23 AM
