I need help with my camshaft setup with oversized vavles..
which camshaft do you guys think I should run on my jdm h22a setup I have oversized valves, I want to get the crower stage 2 cams but it says that not to use with oversized valves...and is anybody run crower cams with oversized valves? I need help bad cause I get some camshaft to finish off my setup
thanks for the help.
Well, they say not to run oversized valves for a reason. Skunk2's website also reads the same. I suggest giving those to someone - or selling them. The oversized valves makes the incomming air non-efficient. It doesn't flow in like its supposed to. It has more surface area of the valve to pass.
