cam seals
ok..the side of my engine where the headgasket, timing belt cover, valve cover is leaking major oil...so I figure the cams seals in there are bad....the question is that when I take out my sprockets..can I just try to dig out the cam seals or do I need to take out shafts as well? Me being stupid...when I had replaced my shafts, valve springs, retainers, etc....I never replaced those 2 seals.....and now its leaking oil....Im just trying to save time and cant recall if I can just dig out those 2 seals....the thing Im worried is that...I already had it dyno tune and dont wanna mess up any of my set up.....
2 seals that im talking about....
you dont even need to remove the cam gears.... jus take off valve cover etc, then the cam plates, and then 2 camcovers and replace seals. Then torque the cam plates to 20ft lb in criss cross patern and BAM ur done!
easy as chicken pot pie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import810 »</TD></TR><TR><TD CLASS="quote">you dont even need to remove the cam gears.... jus take off valve cover etc, then the cam plates, and then 2 camcovers and replace seals. Then torque the cam plates to 20ft lb in criss cross patern and BAM ur done!
easy as chicken pot pie</TD></TR></TABLE>
ok mank...your thinking of something else, because you NEED to remove the cam gears to replace those cam seals.
Modified by projectTeG at 1:57 AM 10/27/2005
easy as chicken pot pie</TD></TR></TABLE>ok mank...your thinking of something else, because you NEED to remove the cam gears to replace those cam seals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import810 »</TD></TR><TR><TD CLASS="quote">isnt this is it?
were talking about the ones were the cam gears are.
</TD></TR></TABLE>were talking about the ones were the cam gears are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZR4DR »</TD></TR><TR><TD CLASS="quote">Do you know how to put on a timing belt and properly adjust the tension? If you don't you can very easily mess up your motor.</TD></TR></TABLE>
very very trure, also i would reccomend going to http://www.c-speedracing.com and reading their how-to's or checking out the articles on http://www.team-integra.net
yes I know..
yes I know..
I recently did mine. Pulled off the cam gears, and the top end caps. I wiped a thin coat of some black RTV gasket stuff around them on the outside and then slid them on. Then put on the top end caps back on. I got them from Acura, and they had some clear grease on the inside V grove where it goes on the cam. I had some other ones that I got for a different motor that didn't have that grease (I didn't end up using these). So you might look into that.
nexgen91
Jul 31, 2007 07:08 AM
