hasport mounts?
so i have 2 totally screwed top mounts , ill post pics when i change them they should be horrible , but anyways , the shop i go to has the dc2 replacement mounts but in 62 a hardness, i had the 70a mounts in my civic and loved them , the shop says they have the 70 a inserts from hasport if i want them on the side for 15 bux , now my real question , how hard and what do i have to do to change the inserts in the new mounts , will i need a press or anything or should i be able to do it in my garage? i don't want to spend all this money and find out its another 50 bux to have them pressed in or whatever is nessassary thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-501itrspec »</TD></TR><TR><TD CLASS="quote">how hard and what do i have to do to change the inserts in the new mounts , will i need a press or anything or should i be able to do it in my garage? i don't want to spend all this money and find out its another 50 bux to have them pressed in or whatever is nessassary thanks</TD></TR></TABLE>
You can change the Hasport mount's urethane using a press or without. It is possible to do this without a press, in your garage, but is hard to get the pin in the 70A urethane perfectly lined up in the mount without the press. A simple arbor press will make the process a lot more simple. I dont think it would cost you $50 to change the urethane. It takes about 1 min with an arbor press. The shop selling you the mounts should do it for free especially if they have a press. Also, the pin presses into the urethane a lot easier if you put a little grease on the pin.
good info thanks alot , i dont know if the store im gettin them at has a press , but my mechanic probbally can figure out how toi get them out
D16SohcVtec
Aug 12, 2008 08:03 AM
racingant
10
Mar 13, 2004 07:17 PM
