D16Y8 manifold differences
Old Oct 25, 2005 | 06:28 PM
Civic Racer X 7's Avatar
Default D16Y8 manifold differences
any difference between the 96 97 98 99 2000 auto and manual tranny D16Y8 manifolds
or are they all the same
I have a d16Y7 boosted and need a D16Y8 manifold to use a chipped P28 and jumper harness
Old Oct 25, 2005 | 06:44 PM
turboman's Avatar
Default Re: D16Y8 manifold differences (Civic Racer X 7)
Not sure of the difference year to year but the auto has the idle control valve blocked off.
Old Oct 26, 2005 | 01:38 PM
so I cna use it as PLUG n PLAY for my bootsed 98 civic w/ jumper harness and a chipped P28 without having to cut a bunch of wires?
PLUG N PLAY?
Old Oct 26, 2005 | 01:41 PM
xCIVICx's Avatar
Default Re: (Civic Racer X 7)
is the ecu auto or standard?
Old Oct 26, 2005 | 02:05 PM
not sure its a P28 chipped with neptune basemap
Old Oct 26, 2005 | 03:08 PM
xCIVICx's Avatar
whats the number on the ecu? that should tell you
let me know if you need to know the number for the manual.. i will go check my spare.
Old Oct 26, 2005 | 03:24 PM
Marauder's Avatar
Default Re: (xCIVICx)
manual tranny manifolds have the idle control valve bolted to the back of the manifold, all auto tranny's they are on the throttle body.
96-98 have a smaller mounting flange since the 99-00 civic's have air-injection that's feed to the mounting flange of the intake manifold.
Old Oct 26, 2005 | 04:35 PM
so in simple terms an auto Y8 manifold will be just as easy to swap and just as good for boost application?
Old Oct 26, 2005 | 06:17 PM
VRD^sam's Avatar
First of all is your car auto or manual...if its auto then you have to use the auto d16y8 intank manifold(will make life alot easier...and if its manual then, you havet to use a manual intank manifold( way easier)....
Old Oct 26, 2005 | 06:52 PM
I have a 98 honda civic DX manual
777sC
20
Jun 11, 2023 11:54 AM
ngarover
Mar 6, 2015 03:54 PM
urname7698
Jun 9, 2003 04:13 AM
Quetzolcotl
Oct 23, 2002 11:52 PM
