which alty h22 in accord ( I SEARCHED )
Old Oct 25, 2005 | 04:17 PM
sleepystyle's Avatar
Default which alty h22 in accord ( I SEARCHED )
i searched i cant find it.. am i keeping the preludes aternator or do i have to swap the accords alty and bracket onto the preludes block ?
Old Oct 25, 2005 | 04:56 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: which alty h22 in accord (ninjaskillz)
Use the accord aleternator...and switch the pullies if you are using a prelude underdrive pulley.
Old Oct 25, 2005 | 05:05 PM
ok so y the accords would the prelude not hook up with the wire harness or what
Old Oct 25, 2005 | 06:19 PM
-Bionic-'s Avatar
Former Sponsor
Which alternator do you have right now?
Old Oct 25, 2005 | 09:50 PM
i got the prelude one that came with the h22.. but i also kinda wanna sell it if i can use the accord ones
Old Oct 26, 2005 | 07:32 AM
-Bionic-'s Avatar
Former Sponsor
You can use either one, but remember that the accessory belt from a prelude is different than the accord. So you need to make sure that the pullies are for the same car. The alternator and A/C compressor from both the accord and prelude will bolt up and line up...The only exception is the p.s pump.
Old Oct 26, 2005 | 11:07 AM
Default Re: which alty h22 in accord (-Bionic-)
okkk so which P/S am i using can i use the accords one ?
Old Oct 26, 2005 | 02:24 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjaskillz &raquo;</TD></TR><TR><TD CLASS="quote">okkk so which P/S am i using can i use the accords one ? </TD></TR></TABLE>
Depends on which accord and which H22 engine you have.
The prelude bracket and p/s pump lines up perfectly...However; the p/s hose or line..whatever you want to call it is not flush when you use the accord p/s line. Thus, you need everything from a prelude as far as the power steering goes....line, pump and bracket...
If you want to use the accord line and pump, you still need the prelude bracket, but the one from 97+.
Old Oct 26, 2005 | 02:36 PM
ok well i need the A.C compressor from the accord ... and alternator from accord and P/s from prelude just change all the gears on it to a prelude one ??
would it make more sense to just buy those aftermarket gears for preludes and put tem on the accords atly and A.C and use the prelude belt
Old Oct 26, 2005 | 02:46 PM
-Bionic-'s Avatar
Former Sponsor
When you are saying gears, I am assuming you mean pullies.
You only need to change the pullies if you intend on using the prelude underdrive pulley. Since you have all the accord parts, why don't you use the accord underdrive pulley...b/c then you can keep all of your accord parts. Remember to get the prelude 97+ p/s pump bracket.
Old Oct 26, 2005 | 04:28 PM
oh yeah... so all i need is the prelude bracket and the accords P/S pump will work fine ?
Old Oct 26, 2005 | 05:29 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjaskillz &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah... so all i need is the prelude bracket and the accords P/S pump will work fine ?</TD></TR></TABLE>
Yes...assuming that you have a 98-02 accord, and the bracket is from a 97+ prelude.
Old Oct 26, 2005 | 07:07 PM
i have a 92-96 h22 and a 95 accord
Old Oct 26, 2005 | 08:27 PM
-Bionic-'s Avatar
Former Sponsor
I have that engine too.
The same should apply as well, but I"m not 100% sure.
Old Oct 26, 2005 | 10:00 PM
jakeiscool's Avatar
Banned
For powersteering here is what you need
1. if the h22 is 97+ you can use that pump with the accord hardlines, perfect match
2. if not 97+ you need a prelude ps pump BRACKET and use the accord ps pump and hardlines
3.or you can delete it like me unless you are a nancy
Old Oct 26, 2005 | 10:02 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: which alty h22 in accord (JakeIsCool)
True that
I removed the p/s with the swap too. B/C I didn't feel like forkin out the extra 80 dollars to get a prelude hose.
I like it without p/s. Allows you to get a better feel of the road.
Old Oct 26, 2005 | 10:03 PM
jakeiscool's Avatar
Banned
haah exactly, expletive spending more money than you need to just to have amenities that you can live without.
Old Oct 26, 2005 | 10:10 PM
-Bionic-'s Avatar
Former Sponsor
ooh btw. I forgot toe mention this. I also freeded up 2lbs.
Old Oct 27, 2005 | 01:44 PM
hmmmmmmmmmmmmmmmmmm maybe i should just forget about the P/S....
well is it hard to turn ?? or what
so let me see if i got it right
i got a 92-96 h22 so i use the 92-96 h22s bracket and just swap the accords P/S on to the bracket and no need for any extra hoses or anythin because it will be all hooked up already right ?
Old Oct 27, 2005 | 04:24 PM
Old Oct 29, 2005 | 12:37 AM
bump
Old Oct 29, 2005 | 01:28 PM
bump for unanswered questions
Old Oct 29, 2005 | 01:33 PM
Natz's Avatar
I would keep the p/s for sure i didnt have it in mine for a while but then I finally spliced the hose and it works great very worth it
Old Oct 29, 2005 | 01:36 PM
Natz's Avatar
dump the a/c lol keep the p/s
Old Oct 29, 2005 | 10:37 PM
i am dumping the A/C but yeah i guess i do want to keep the P/S pump so i keep the accords P/S pump and use the preludes bracket and bolt it on the h22.. so no need to take off any hoses for the P/S pump so simple swap right ?
hondaracin24
Dec 21, 2006 01:53 PM
huge230
Sep 7, 2005 04:12 PM
ludedude2
May 11, 2005 04:24 AM
wizzards581
Sep 14, 2004 08:08 AM
