burning oil?
Old Oct 25, 2005 | 03:35 PM
93preludesi93's Avatar
Default burning oil?
what are the most likely causes of my 93 lude burning oil.. I have to add about a quart of oil every 1000 miles.
Old Oct 25, 2005 | 03:38 PM
petern101's Avatar
Default Re: burning oil? (93preludesi93)
vtec? cause there are a good number of h22's that eat oil
could also be a leaking cam seal
Old Oct 25, 2005 | 03:51 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: burning oil? (petern101)
There are sooooo many causes for losing oil. How do you know you're burning it and not leaking it?
Cam seal
Valve cover gasket
Spark plug grommets
Headgasket
Oil pan gasket
Piston rings
Blowby
Random leak somewhere....
Old Oct 26, 2005 | 10:54 AM
Default Re: burning oil? (shamoo)
well it has white smoke when you start it. and I dunno if this will help in diagnosis but there is a metal grinding on metal sound, only within the first 2 miles of driving, as in the motors not heated up, and only when i get over 2,500 rpm. and i've never seen any drips.
Old Oct 26, 2005 | 11:34 AM
The_Sober's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludesi93 &raquo;</TD></TR><TR><TD CLASS="quote">well it has white smoke when you start it. and I dunno if this will help in diagnosis but there is a metal grinding on metal sound, only within the first 2 miles of driving, as in the motors not heated up, and only when i get over 2,500 rpm. and i've never seen any drips.</TD></TR></TABLE>
white smoke is usually a blown head gasket. Are you sure it's not bluish? you could need new rings, or valve seals. it depends on when it's burning when you drive. does it do it when you accelerate, does it do it when you hit VTEC, or does it puff smoke when you shift?
but VTEC is the cause for a lot of oil consumtion--mostly blow-by on mine I've noticed...
the grinding noise is probably your trans. you should make sure the car warms up before you drive it. a flush/fill on your trans wouldn't hurt.
adizzlejdm
Dec 4, 2010 10:31 AM
AccordOn18z
Sep 27, 2007 07:18 PM
mike93eh2
14
Aug 13, 2006 05:33 AM
98cwitr
Apr 27, 2004 01:34 PM
Jan 20, 2003 06:20 PM
