Compression test and leak down...
Old Oct 25, 2005 | 02:50 PM
P@@RB@Y's Avatar
Default Compression test and leak down...
Will a compression test tell me everything a leak down would tell me?Or should i do both?
Im trying to find out if the motor was damaged from running to rich.
Also is there a way to find out if a engine has ever had Boost or Nitrous?
Thanks
Old Oct 25, 2005 | 03:58 PM
NJIN BUILDR's Avatar
Default Re: Compression test and leak down... (P@@RB@Y)
The compression test will help tell if there is a problem.The leakdown will help tell what the problem is.I don't know of any definitive way of telling if a motor was ever boosted or was on the bottle.
Glenn
Old Oct 25, 2005 | 04:10 PM
P@@RB@Y's Avatar
Default Re: Compression test and leak down... (NJIN BUILDR)
So compression test and if the numbers arent close do a leakdown test.
What should the numbers be on a B16A2?
76 camaro car
Apr 20, 2017 04:47 AM
crazyhouse2011
Mar 18, 2013 07:50 PM
humboldt_skim
May 31, 2008 08:18 AM
Got_soy
28
Aug 8, 2005 12:49 PM
