My engine is now wire less :)
Finally got around to installing my harness that i made. took 35 hours to make the harness
Painting bay Flat black.. it was turning PINK
Damn Hard Lines
Battery and fuse box.. where'd it go? I dunno
Fuel pressure gauge line. Throttle Linkage, Fuel Return, ANd HARDLINES!
new intake manifold on the way to get rid of those damn vaccum block offs
Take me to your leader... HID's warming up in the fogs straight custom did..lol
looks kind of mean to me
HARD!!!!!
Damn Hard Lines
HARD!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">the bay is getting blasted next spring when it gets repainted so this is only TEMP</TD></TR></TABLE>
gotcha
gotcha
Guest
Posts: n/a
Finally!!!!!!!!!!!!!
Your car is damn fast, and I always wondered why you didn't get rid of that shitty *** stock B16A intake manifold. It will make a nice difference in top end power
Which one are you going to get?
Blox or JG.. cause a snail might crawl into my exhaust.
BTW The HID's are
Headlights - Denji old school housings with BMW 745il Bixenon Projectors, D2S Phillips 4100k bulbs, Hella GEN 3 ballast
Foglights. IS300 Retrofitted on stock EG brackets. IS300's have a custom housing to accept Osram 4300k bulbs with BMW ballast and ignitors
BTW The HID's are
Foglights. IS300 Retrofitted on stock EG brackets. IS300's have a custom housing to accept Osram 4300k bulbs with BMW ballast and ignitors</TD></TR></TABLE>
i bet you have either typed that out or copy and pasted so many times lol
looks good.... whats this about a snail crawlin into your exhaust
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote"> a snail might crawl into my exhaust.
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOoo ooooooooooooooooooooooooo!!!!!!!!!!!!!
You're reppin' hard for the One-thousand Five-hundred ninety-five cubic centimeters of fury. All motor B16A running 13.6=
Yea you should have def done a little more prep work on the bay few more hours of prep would have turned out much cleaner....even take out the headlights takes like 2 seconds...anyhow nice job on the wiring...
Duplicolor auto spray finish is your friend, it is transparent and you probably could have matched your color even if temporary. Here is mine frost white Duplicolor spray, and my **** was so dirty it turned grey.
I like the tuck, and keep repin the almota B16
Oh yeah, nice header
Justin
Justin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEK9 »</TD></TR><TR><TD CLASS="quote">Really Clean!!!</TD></TR></TABLE>
