Windshield vipers and blinkers went out. HELP!
Old Oct 25, 2005 | 01:42 PM
killah3084's Avatar
Default Windshield vipers and blinkers went out. HELP!
I have a 93 accord Lx. My windshield vipers are on the loose. when i put on the switch i can hear motor work but they stay still. Also my water spray works only when the hood is up... Freaking weird car. It got a mind of its own, i swear.
My blinkers work for hazards but not left/right. green arrows don't turn on either.
How do i fix them?
Thanks,
-V-
Old Oct 25, 2005 | 01:59 PM
13lue's Avatar
Default Re: Windshield vipers and blinkers went out. HELP! (killah3084)
For the wipers/blinkers it could be a fuse or a bulb, for the windshield fluid the tubes could be clogged up.
Old Oct 25, 2005 | 02:06 PM
Gearspeed-Performance's Avatar
I had too!! LOL
All joking aside...Do as mentioned above and check all your fluid lines for your squirters. Also check the actual wiper where it attaches to the motor to see if they are properly connected or disconnected for some funny reason from the previous owner.
Old Oct 25, 2005 | 03:50 PM
deserthonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killah3084 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 accord Lx. My windshield vipers are on the loose. when i put on the switch i can hear motor work but they stay still. Also my water spray works only when the hood is up... Freaking weird car. It got a mind of its own, i swear.
How do i fix them?
Thanks,
-V-</TD></TR></TABLE>
if u can hear the motor running then the fuse is ok, chk the nuts at bottom of wiper arms make sure they are tight, also chk the linkages they might be broken or unattached,, as for the water not spraying with hood closed u need to rerout the tubing, it is getting kinked when hood is closed most likely trouble spot, driver side lower part of the hood where the tubing comes from the fender , if they work with hood up then they are not plugged
Old Oct 26, 2005 | 03:11 PM
VTEC22's Avatar
Default Re: Windshield vipers and blinkers went out. HELP! (deserthonda)
yea as said above check the nuts attaching the wiper blades to the motor if its been doing this for a while it may have stripped the little griping parts that stop it from slipping ive seen it happend to a few cars.
Old Oct 26, 2005 | 04:12 PM
killah3084's Avatar
Nuts are fine. Fuse fine, motor fine. Linkage - can't unscrew the bolt yet - its pouring like crazy.....
ergot
Jun 20, 2006 10:11 PM
cloudx71
Mar 28, 2005 08:47 PM
ApexIS300
11
Aug 12, 2004 03:46 PM
undertheradar
12
May 18, 2004 11:31 AM
saanemon
14
May 29, 2003 01:50 PM
