throttle body questions
Old Oct 25, 2005 | 01:16 PM
Ur 2 Slow 4 J's Avatar
Default throttle body questions
ok on a throttle body, right before the TB plate, theres a hole on the left. what is that called, where does it go to, and why is my idle irratic and then when i plug that hole up it goes back to normal. please respond ASAP its costing me gas
Old Oct 25, 2005 | 03:54 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: throttle body questions (Ur 2 Slow 4 J)
That should be your IACV (Idle Air Control Valve). It lets air inside the manifold even when your throttle plate is closed. This allows your car to idle, or stay on when you're not pressing the gas.
When is your idle erratic? All the time? Or just during cold starts? You most probably have a dirty IACV. Do a general search on it, and you will find a how-to on how to clean it. It has solved most people's idling problems.
Old Oct 25, 2005 | 04:21 PM
problem solved. the fitv white thingy was loose. now it works great
Old Dec 30, 2005 | 04:32 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (Ur 2 Slow 4 J)
Does anyone have any pix of the hole that he is talkin about? I cleaned out my IACV and it didnt help me. Now I am thinking about taking off my throttle body and doing thing http://www.92lude.com/idle_air...d.htm. Can anyone help me? I know this has been covered many times, but I cant find my answer to this and obviously I DID SEARCH.
Old Dec 30, 2005 | 07:30 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (AnthonyG2003)
bump
Old Dec 30, 2005 | 07:49 PM
Rosko's Avatar
Sounds like one of "Brady's free mods" from back in the day
Couldnt you just unplug the IAC valve to see if it stops surging? Of course that would throw a check engine light but it should tell you if the iac is being irradic.
EVS90
Mar 16, 2014 04:27 PM
DeLSoLRo
20
Apr 23, 2011 10:06 AM
magicguy
Jan 30, 2009 02:00 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
k_lude
Oct 2, 2006 07:25 PM
