h23 to h22
Old Oct 25, 2005 | 01:12 PM
BDRphaSe2's Avatar
Default h23 to h22
i know there must be alot of threads, but i swapping a jdm h22 from my usdm h23a1. also the h22 tranny, i just wanted to know if its all plug and play im getting the nessessary parts like axels tranny ecu harness etc. just wanted to know if i can drop the h22 and tranny right in with no mods hoping its just plug and play. please dont say search can i have and i cant find so whoever says search can f off
Old Oct 25, 2005 | 01:35 PM
Mad Hatter's Avatar
Default Re: h23 to h22 (BDRphaSe2)
what type of prelude is it and what year? if you have the ecu and everthing, i'm pretty sure it'll drop right in
i would also definitely try searching a little bit harder
Old Oct 25, 2005 | 01:40 PM
bb6h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDRphaSe2 &raquo;</TD></TR><TR><TD CLASS="quote">i know there must be alot of threads, but i swapping a jdm h22 from my usdm h23a1. also the h22 tranny, i just wanted to know if its all plug and play im getting the nessessary parts like axels tranny ecu harness etc. just wanted to know if i can drop the h22 and tranny right in with no mods hoping its just plug and play. please dont say search can i have and i cant find so whoever says search can f off </TD></TR></TABLE>
I say, people too lazy to provide enough detail in their posts to give the reader a clue as to what question it is they're being asked, can expletive off.
Old Oct 25, 2005 | 02:04 PM
InvaderTrax's Avatar
Default Re: h23 to h22 (i'm so lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i’m so lude &raquo;</TD></TR><TR><TD CLASS="quote">what type of prelude is it and what year? if you have the ecu and everthing, i'm pretty sure it'll drop right in
i would also definitely try searching a little bit harder</TD></TR></TABLE>
Well, it's most likely a 92-96. Probably Si
Old Oct 25, 2005 | 02:10 PM
Televator's Avatar
Default Re: h23 to h22 (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">
Well, it's most likely a 92-96. Probably Si </TD></TR></TABLE>
Yeah the H23 part gave it away. I'll be damned if he bought a fifth gen that someone put an H23 in before.
Old Oct 25, 2005 | 02:17 PM
BDRphaSe2's Avatar
lol ya i thought the h23 was a dead give away but for those who still wanna know its a 4th gen 94 si, is it all plug and play ? i will have axels ecu tranny harness t body in and ex manifolds dizzy start clutch flywheel etc lol all essentials so is it plug and play ??? thanks for help
Old Oct 25, 2005 | 02:19 PM
05member y0's Avatar
http://www.superhonda.com/foru...41207
that has all you need to know.
Old Oct 25, 2005 | 03:06 PM
shutta's Avatar
swap teh manual tensioner from the h23 to teh h22 while you are at it
Old Oct 25, 2005 | 04:14 PM
Turbo-GSR1287's Avatar
Default Re: (shutta)
yeah i plan to swap my h23 for an h22 within the next few months....its very straightforward.....i helped my firend do his......not hard at all
Old Oct 25, 2005 | 04:17 PM
SteveoBA8's Avatar
Default Re: (-95LudeSI-)
Use your H23 fuel rail.
Old Oct 25, 2005 | 06:58 PM
Mad Hatter's Avatar
haha...yeah, that probably makes sense
Old Oct 25, 2005 | 08:16 PM
shutta's Avatar
i'm in the middle of swapping my h22 also.. quick question... where did you guys mount your external coil? and why can't I find the plug it connects to?
Old Oct 25, 2005 | 09:08 PM
petern101's Avatar
i just ziptied it to the ac line, you can make a bracket
you have to rewire the external coil
Old Oct 25, 2005 | 10:58 PM
Styler93GSX's Avatar
Default Re: (petern101)
Do a search on my name I just did the swap and I have alot of info in my threads.
Old Oct 25, 2005 | 11:04 PM
Sabbotage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">i'm in the middle of swapping my h22 also.. quick question... where did you guys mount your external coil? and why can't I find the plug it connects to? </TD></TR></TABLE>
When i did mine i bought the coil bracket from hondaautomotiveparts.com for a 5th gen prelude and it bolted right up. If you are good and have the metal you can fab one up yourself, but when i did mine i didnt have the resources to do that.
Digga4
Jun 11, 2005 02:45 PM
jnet
Jan 15, 2005 10:13 AM
snatch13
Feb 4, 2004 07:32 AM
RuS.
Aug 7, 2003 05:23 AM
DA_KengV
Apr 25, 2003 06:41 PM
