pins on flywheel
search didnt return anything useful....
when re-installing the flywheel after having it resurfaced, I had to hammer the pins back in. It doesnt seem like the pins all went in an equal distance. It is hard to tell though. Will this effect the pressure plate mounting on the flywheel ?
Will it be ok, or do i need to be absolute certain that the pins are all hammered in equal distances?
Help is appreciated quickly as I am in the garage as I type installing it.
They should have gone in the same amount, but it is not critical. What is important is that the pressure plate is centered, which is the purpose of the dowel pins.
