d15b8 mini-me
Old Oct 25, 2005 | 12:13 PM
agp1183's Avatar
Default d15b8 mini-me
Ok, ive searched a bunch and I am still not sure what heads will work. Will any D series head work? Which timing belt goes with which head?
Also, is there a way to remove the head without ruining the head gasket so I can check to see if I have 4 valve reliefs? Or any easier way to check for valve reliefs?
thanks in advance
Modified by agp1183 at 1:28 PM 10/25/2005
Old Oct 25, 2005 | 04:39 PM
92ehatch's Avatar
Default Re: d15b8 mini-me (agp1183)
if you can find out if it is 4 valve reliefs use Bauley civics writeup to do the rest.
also, i think i saw a thread on here a few days ago asking a similar question, something about the newer ones have 4 valve reliefs, but i dunno which ones.
here a link, and a bump
https://honda-tech.com/zero...age=1
Old Oct 25, 2005 | 05:56 PM
agp1183's Avatar
yea i read over that whole thing, just was still a bit confused. If its true that only the newer civics have 4 valve reliefs, then im probably out of luck with my 92...
I'll probably read over that again, now that im more awake.
Old Oct 25, 2005 | 06:14 PM
agp1183's Avatar
ok I did a google search and came up with the answer that all d15b8's have 4 valve reliefs... d15b6's only have 2.
Anyone with a d15b8 ever run across 2 relief pistons?
Old Oct 25, 2005 | 10:42 PM
92ehatch's Avatar
Default Re: (agp1183)
maybe the local honda dealership can tell you?
even if someone has come across it, wont really help you figure out what you have.
best thing to do is remove head and check i guess.
or just do a full z6 swap
dominate9
Apr 14, 2020 02:10 PM
451MO
Aug 22, 2014 11:38 AM
TheTealHatch
May 28, 2008 03:05 AM
Space Boy
May 30, 2002 12:46 AM
