replaced clutch and flywheel now car won't start
everything is back to gether.. bled the clutch.. it turns over..and now it won't start..did a search and someone said maybe a clutch switch from disconnecting the hydrolic lines..don't know but i've spent three f-ing days on this just always seem to be one thing after another..still worth the 400 i saved doin it myself..any info is helpfull thanks...
Wish I was there to have a look at it. I would assume you just didn't hook something back up correctly: battery ground, dizzy, spark plug wires, etc.
Yeah, it's probably just a little wiring thing... Check all your grounds, like the one for the ECU on the thermestat housing, the tranny ground, check the ignition components (coil, plug wires, etc), check for fuel pressure....it could be lots of little stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludster »</TD></TR><TR><TD CLASS="quote">check the starter</TD></TR></TABLE>
He said it turns over......
the only stuff i disconnected was the vs plug and starter wires the batteryan o2 sencsorand thier all connected...whats up with the clutch switch..i have good pedal pressure feel.. thought it would be stiffer for a stage 3 clutch is this my problem and how do i fix it..before hand it would fire right up so i don't think its fuel or spark seeing how i didn't touch any of that stuff.. i'll keep at it.. please help.
ge_ej1
Mar 16, 2008 07:25 AM
EK k kay
Jun 19, 2006 10:25 PM
MugenFlaredCRX
Dec 8, 2005 05:05 PM
MiMiK
Jul 11, 2005 11:14 AM
