what specs of 20'' rims and tires would fit my 2003 honda accord
225/40/19s will fit, I don't know if you can go to 20. That would be like rubber bands on rims.
clay@tirerack might be able to help you.
checked tirerack using an i4 sedan and 19s, 8.5s appear to fit if you get an offset between 46 and 50. recommended tire size is 225/40. if you kept the tire width the same as the 19s, you need to find a tire close to 225/35/20 to get the same overall diameter. however, this size does not appear to exist so you might have to see is available and go from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">225/40/19s will fit, I don't know if you can go to 20. That would be like rubber bands on rims.</TD></TR></TABLE>
No kidding. And your expensive wheels will be very susceptible to damage from potholes and bumps in the road. Maybe if it's only a show car that is never driven on the street, otherwise I wouldn't recommend it.
this guys is trying to sell his 18'
18 x 8 wheels /w 245/35 zr 18 Tires
18x9 wheels /w 265/35 zr 18 Tires
i dont know if this would fit on the 03 accord. i am getting an owesome deal
the 265/35s are fairly close to the OE overall daimeter (off by about .3" by my calcs) but those tires and those rims are awfully wide. You might get rub, and check to make sure you have the right offset on those rims.
20s will fit. not exactly sure width or tire size but my aunt has an 03 accord wit 20s on it and a friend of mine as another 03 wit 20s on it i think it looks lovely
