Help!!!!
i got a 92 civic hatch si, i recently changed the water pump and it seems to work fine now..but my underpully from the crank shaft shakes like its loose. i tried tighten it up again but still shakes...anyone know what could be the problem, as far as i know...the under pully should not shake like that....lmk...need this fix...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">The crank pully only goes on a certain way. Your sure its on right?</TD></TR></TABLE>
will i wasn't the one to put it in..my brother did...but the crank pully only slides in, in one way...i'm sure we put it on correctly...i don't know what could be the problem....we got everything on, but when the engine is running..you could see the big pully that is connect to the crank shake...not sure what the problem is...
The little key thing could be getting worn out or he forgot to put the washer/plate thing back on with the crank pulley. Just some things to check out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mc »</TD></TR><TR><TD CLASS="quote">The little key thing could be getting worn out or he forgot to put the washer/plate thing back on with the crank pulley. Just some things to check out.</TD></TR></TABLE>
how many washer are there....isn't there 2 or 1
okay, i double check everything today....everything looks fine...but that **** still hella shakes...
could it be the that big pulley that is fucked up or could it be something else, timing?.....help...son-of-bitch is getting annoying....help me out..thanks
