Dim check engine light, fuel pump wont prime, help!
I have two classes and work today, and my car wont start
I have a 1998 Civic DX, its turbo.
All of my lights are bright (headlights, cluster lights, etc.) except my check engine light. When I have the key in the on position, i hear a ticking noise near my ECU, but the ECU isnt ticking. Is that my main relay?
My fuel pump wont prime, hence my car wont start. Anywhere to start looking?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHFAST94 »</TD></TR><TR><TD CLASS="quote">check the fuel pump ground near the t_stat and the main relay.</TD></TR></TABLE>
Makes sense, I did the Tstat almost a month ago. I'll do that now and come back
6 pack for you my friend. thanks.
Well since your reading this post, would that cause my car to "bog" every once in a while? when i get on it sometimes the car falls on its face and starts back up. Would this ground being loose be the culprit?
I pm'd you this too.
olds1983
Honda Civic (2001 - 2005)
Dec 2, 2012 06:34 PM
Phil McConkey
Feb 25, 2007 07:42 PM
