Lost the Rotor mounting screw
I started up my car today and it wouldn't start. I checked the distributor cap and found pieces of the leak cover inside the cap. Couldn't find the screw though.
Question: Is the mounting screw non-magnetic (won't get picked up by a magnet) ?
I'm just concerned that it might still be in the the distributor housing and could cause more damage if it flew off if its currently stuck on a motor magnet. I'm thinking that it dropped out when I removed the distributor cap though.
I know this happens to at least a couple other people. Where did you find your screw?
Usually when the screw falls out, it'll tear up everything inside from the cap to the rotor. I think ITRacer121 has a few pic of what happened to his when his came loose after a day of dyno tuning
. If you haven't found it, it's probably somewhere on the floor.
I found my screw on the garage floor a couple of days later. My local Acura dealer did not stock the rotor button screw so I got one for a 2000 Civic Si. Worked just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arren123 »</TD></TR><TR><TD CLASS="quote">
Question: Is the mounting screw non-magnetic (won't get picked up by a magnet) ?</TD></TR></TABLE>
Helms specifies a "screw made of diamagnetic material".
littlegreenb18
Jun 24, 2006 10:02 AM
GRM Scott
Mar 1, 2002 04:41 PM
