Is d17 flywheel 212mm?....d16/d17 have diff. tranny splines?
Old Oct 24, 2005 | 10:40 PM
jBj's Avatar
jBj
Default Is d17 flywheel 212mm?....d16/d17 have diff. tranny splines?
Hey guys, I am going to do an exedy stage 1 clutch on my bros 2002 civic si-g.
I need to know if the d17 flywheel is 212mm, if not exedy stated I need to use the 212 d16 flywheel in order to use the clutch kit.
Also, does the d17 tranny have different splines than the d16 tranny? I may also be able to get a d16 exedy clutch w/ d16 flywheel and use that instead, for cheaper .
thanks.
Old Oct 25, 2005 | 11:31 AM
djmota's Avatar
Default Re: Is d17 flywheel 212mm?....d16/d17 have diff. tranny splines? (jBj)
late d16 and d17 use the same clutch and flywheel. You do not need to change your flywheel. Just get it resurfaced.
Old Oct 25, 2005 | 06:04 PM
jBj's Avatar
jBj
Default Re: Is d17 flywheel 212mm?....d16/d17 have diff. tranny splines? (djmota)
Ok cool, so the late d16 and d17 def. both have 212mm?
thanks
Old Oct 26, 2005 | 09:49 AM
djmota's Avatar
yup I am using exedy stage one clutch in my em2 and luv it
Old Oct 26, 2005 | 12:35 PM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmota &raquo;</TD></TR><TR><TD CLASS="quote">yup I am using exedy stage one clutch in my em2 and luv it </TD></TR></TABLE>
So you are using this organic one?:
http://www.coximport.com/store/EX08801A
thanks man
Old Oct 28, 2005 | 11:30 AM
djmota's Avatar
YUP
Old Oct 30, 2005 | 09:52 AM
jBj's Avatar
jBj
Thanks for your replies djmota. Got the clutch done yesterday, took a long long time, that d17 tranny is a bitch. Ended up having to remove both axels to slide it in.
For reference clutch part # 08801A.
Old Dec 8, 2010 | 01:22 AM
HondaDNA93's Avatar
I know this old but just in case someone finds it from searching(like I did). The D17 flywheel is not the same as the D16, yes they both are 212 and have the same teeth count but the D17 is 22lbs vs the D16 19lbs. You can swap them thou.
Old Dec 8, 2010 | 05:01 AM
turboteg2nv's Avatar
Good info
big_daddy234
Sep 21, 2009 07:48 PM
ludesrv
14
Jun 2, 2006 07:05 AM
JapJunkie
Dec 1, 2005 06:24 PM
allmotorek8
10
Nov 3, 2005 06:37 PM
StolenTeg
Aug 3, 2004 10:33 PM
