need help wiring my IAT code 10 itr swap
Old Oct 24, 2005 | 08:13 PM
gato5254's Avatar
Default need help wiring my IAT code 10 itr swap
ok here is some back ground i have a itr swap in a 96 hatch i'm throwing two codes 41 and 10 i know what they are and how to fix 41 adding a O2 sensor thats later but right now i'm trying to fix the code 10 could some please help by SHOWING "PICS" which plug it goes to. i know where the sensor is but i don't understand the manuel when it tells me the plug on the ecu. if i confuse any one sorry. but i just want to see where the sensor wires go on the plug connecting to the ecu. because i don't have any wiring connecting at the sensor and i looked for the color wires that i'm suppose to wired to it but nothing. please help. the car is a 96 cx hatch w a 96-98 ex wiring harnness and the engine is a 96 itr w p73 stock ecu
Old Oct 24, 2005 | 09:15 PM
Downey's Avatar
Default Re: need help wiring my IAT code 10 itr swap (gato5254)
you shouldnt have to have changed any wiring for the iat sensors.
the iat sensors is on the number 2 cylinder intake runner.
Old Oct 24, 2005 | 09:23 PM
gato5254's Avatar
Default Re: need help wiring my IAT code 10 itr swap (Downey)
no i don't have the wires i'm not trying to change them i'm try to put them there. i guess the guy that did my swap poked me in the eye but he didn't hook it up, he cut some wires and just left a mess. i fixed most of them but i don't know where to wire the iat sensor to the ecu. i think it's called the ecu plugs i just need to know which one to wire it to. it know it's two wires but i can find them in the engine bay so i think it would be easier to just route new wires to the sensor
Old Oct 24, 2005 | 09:30 PM
Downey's Avatar
this should help
Old Oct 24, 2005 | 09:40 PM
gato5254's Avatar
ok one plugs to connector D pin 8 but where does the other one go it has two
got it thanks man
http://www.ff-squad.com/technet/wiring.obd2a.htm
Modified by gato5254 at 12:08 AM 10/25/2005
Old Nov 2, 2005 | 12:22 AM
allmotorej8's Avatar
the IAT for obd-2a/b 96+ cars is located on the intake arm, rigth before the trottle body. its the wire that splits from the map sensor one. hope that help, you dont need to plug anything up on the manifold's IAT. at least thats what i did
jons91ef
May 28, 2008 08:39 AM
Clipsed
Apr 21, 2008 08:02 PM
91tegrals
Nov 28, 2005 08:41 PM
DancingDorito
Sep 27, 2004 08:40 AM
Waachback
Dec 2, 2003 06:56 PM
