Suspension & Brakes Theory, alignment, spring rates....
traction problems and need advice
Old Oct 24, 2005 | 08:09 PM
toooslow's Avatar
Default traction problems and need advice
I swapped out stock suspension a while back in my 95 teg and threw in Ground control coilovers. After that i could never get traction. I thought it was my shocks so i replaced stock ones with new kyb agx ones. Traction problem stayed the same. I cant even launch at 2000 rpm. tires just spin, no squeeling at all and no tire marks are left on the pavement. Engine is stock b20vtec not making much power.
I looked at the numbers on the springs today and they read
front 200.64.58 which have a spring rate of 330
Rear 180.64.44 which have a spring rate of 280
Does the spring rates sound to low? To me they seem backwards.
Old Oct 24, 2005 | 08:29 PM
chrisw85's Avatar
that seems like the default spring rates for off-the-shelf GCs...
How low are you?
Old Oct 24, 2005 | 08:38 PM
toooslow's Avatar
Default Re: (chrisw85)
about 2 inches lower than stock, have tried with the coilovers raised all the way and still same problem
Old Oct 25, 2005 | 01:39 AM
gsrious's Avatar
you car just has mad torque in the low end.
Old Oct 25, 2005 | 07:19 AM
artifex's Avatar
say it
Default Re: traction problems and need advice (toooslow)
did you get an alignment after you dropped it?
Old Oct 27, 2005 | 06:59 PM
toooslow's Avatar
yes i got an alignment. Tires are just about brand new also.
I called ground control and they said that those coilovers were for a civic. Would that spring rate make that much of a difference?
Old Oct 27, 2005 | 07:44 PM
artifex's Avatar
say it
Default Re: (toooslow)
no, that spring rate is still stiffer than the stock GSR rates... are your motor mounts in decent shape? bushings?
Old Oct 29, 2005 | 09:23 AM
toooslow's Avatar
Default Re: (artifex)
well i just got back from attempting to get another alignment, this is what they suggested that needed to be done before getting an alignment
2 lower control arm bushings
1 outer tie rod end left side
1 inner tied rod end right side
2 rack and pinion belows (dont know what this means exactly)
They also said that the drivers axle has alot of play at carrier bridge
So i guess im going to start off by replacing that axle and maybe get the energy suspension hyperflex master bushing set
Thanks for all the input guys
allmotorlsbaby
Suspension & Brakes
Mar 6, 2009 07:04 PM
modulo_s
Suspension & Brakes
Oct 24, 2005 06:58 PM
BrandonClaps
Nov 7, 2003 10:36 PM
mon2mon2
Aug 9, 2002 12:28 AM
AggAccord03
Feb 28, 2002 02:47 PM
