I belive its carbon build up, not sure though.
Well I was checkin my plugs a little while ago to see how they were doing. Were normal for the idleing I had just done. But I decided to take a peek into the cylinders with a flashlight and I was kinda dissapointed. I believe the cylinders are 4 3 2 1. On #4 the top of the piston was gray, like it was newer. I couldnt see #3 or # 2. #1 had black shiny crap on it. Looks like carbon, according to the few pics I can find of carbon on pistons. The base of the plugs on most of the plugs were black, but nothing on the threads. #1 was a lighter mocha color lol. Is it possible that #1 sees more carbon build up? I think im burning about 1/4 quart of oil per 600 miles or so, with fast highway driving and some quick accelerations. The muffler tip has some soot on it but not bad at all. I want to run Sea Foam but I dont want to expletive things up. The D16Y8 has almost 120,000 on the ticker. Runs like a champ at 34mpg. Can I spray mist into the TB and do it that way or what do you think?
Tryin to give the most info as possible, sorry for the long read.
Why are you afraid of running Sea Foam? I think it could help out your case of carbon, since thats what Sea Foam does is eat away at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green00EX »</TD></TR><TR><TD CLASS="quote">Why are you afraid of running Sea Foam? I think it could help out your case of carbon, since thats what Sea Foam does is eat away at it.</TD></TR></TABLE> Because I have heard when it breaks up the carbon **** moves around and causes some real problems. The car idles fine and everything, Im pretty sure its normal but just wanted some opinions. Anyknow know about misting water in the TB?
Modified by turner7205 at 11:32 PM 10/24/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 »</TD></TR><TR><TD CLASS="quote"> Because I have heard when it breaks up the carbon **** moves around and causes some real problems. The car idles fine and everything, Im pretty sure its normal but just wanted some opinions. Anyknow know about misting water in the TB?
Modified by turner7205 at 11:32 PM 10/24/2005</TD></TR></TABLE>
Seafoam, then change sparkplugs and oilchange.... then do it again right before your next oil change
Rok_Stok
Mar 4, 2010 02:57 PM
EvilRob
17
Jul 20, 2006 03:51 PM
