93 acord idle surging problem
I have a 1993 Honda Accord that surges at idle speeds. As it sits running, the idle runs at normal and then drops to the point where it almost stalls and then picks right back up again. If I press the gas pedal it runs just fine. Does anyone have any ideas about this. I don't want to just start replacing sensors hoping to find the problem. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaynes5334 »</TD></TR><TR><TD CLASS="quote">I have a 1993 Honda Accord that surges at idle speeds. As it sits running, the idle runs at normal and then drops to the point where it almost stalls and then picks right back up again. If I press the gas pedal it runs just fine. Does anyone have any ideas about this. I don't want to just start replacing sensors hoping to find the problem. Thanks</TD></TR></TABLE>
any codes?? chk for vaccum leaks. chk screw at throttle body for adjustment make sure it is not coming unscrewed ..
93cb7se
Mar 16, 2008 08:48 PM
