slicks 60ft. question
Old Oct 24, 2005 | 06:31 PM
bads2k's Avatar
Default slicks 60ft. question
I have been running street tires on my crx b16w/zex dry kit. my 60ft.'s are 2.13.I have my new m&h 22x8x13 slicks and lighter wheels.what should my new 60ft. times improve to and what should i launch at?what psi in the tires?also is it true that if you gain .1 in 60ft. then it's .2 in the 1/4? any help would be great.
Old Oct 24, 2005 | 07:43 PM
Ls1 FD3s's Avatar
Default Re: slicks 60ft. question (bads2k)
23" might be more ideal. 22s on nitrous with a b16 trans, you might be shifting into 2nd gear at or before the 60ft pending your rev limiter, lol.
Should be able to cut 1.7-1.8s with ease otherwise.
Old Oct 24, 2005 | 07:52 PM
Ls1 FD3s's Avatar
Default Re: slicks 60ft. question (Ls1 FD3s)
start on 10psi in tires, preload the drivetrain, 6500rpm, let R rip!
everyone .1 less in 60ft is said to be .15 off ET. That all depends on how consistantly you can shift, traction, etc...
Old Oct 24, 2005 | 07:55 PM
fmfkid250's Avatar
start with 5psi in tires,,,,,,,,,,,,,,,, and get em hot
mid 1.6 all day long,
Old Oct 24, 2005 | 08:02 PM
Ls1 FD3s's Avatar
Default Re: slicks 60ft. question (fmfkid250)
broken LSD and axles soon to follow.
Old Oct 24, 2005 | 08:15 PM
bansheetah's Avatar
Say that again.
Old Oct 24, 2005 | 08:21 PM
Ls1 FD3s's Avatar
Default Re: slicks 60ft. question (bansheetah)
that again.
Old Oct 24, 2005 | 10:48 PM
bads2k's Avatar
man i'm sorry. I didn't put my tire size right. just got them on so forgive me. they are 8.7x25.13 m&h slicks. dpr(dan paramore)draglites 16lbs. each w/tire. also my old wheels/tires were 10lbs. heavier each. how much is this going to help since it's rotating mass? so the taller tire won't make me shift until after 60ft. hopefully right?
Old Oct 24, 2005 | 11:11 PM
Ls1 FD3s's Avatar
Default Re: (bads2k)
man thats the tire i run on my turbo car... in which im well over double and then some your whp...
Honda-Pilot
May 27, 2004 10:00 PM
Waachback
May 6, 2003 01:40 AM
Cyber ITR
Apr 21, 2003 04:54 PM
Kermit EK
Aug 22, 2002 06:35 AM
98civicEX
Aug 17, 2002 04:40 PM
