Motor swap time.....
Old Oct 24, 2005 | 06:27 PM
blowbyu24's Avatar
Default Motor swap time.....
i have a 97 civic and im putting in a obd0 LS motor...i having a problem with trying to firgure out the crank sensor thing...i going to run a obd2 dizzy and ecu...my question is can i use a 96+ LS oil pump, crank sensor and crank gear??? i know i have to change out my rear mount to 99-00 si and my ac mount to b20..is it true that i can use my stock driver????
just to let you guys know..the only reason im going to run this obd0 motor is cause it has been rebuilt....
Koofy23
May 11, 2015 05:14 PM
slowtegkauai
Dec 18, 2010 12:22 AM
sPaRk'iT
Jan 9, 2008 08:31 PM
blowbyu24
Oct 24, 2005 09:53 AM
