How long should the fuel system stay pressurized?
How long should the fuel system stay pressurized after the engine is shut off?
On my 97 LS all OEM fuel components the fuel pressure only holds for 1-2hours on the fuel filter mounted pressure gauge. I have a rough(misfire) idle on semi cold startups and think its a leaky injector. NO CELS and #1 cylinder plug looks slighty rich compared to the other 3. I have moved the #1 injector over to #2 and will recheck the plug in a few days.
Modified by exvtec94 at 3:34 PM 10/24/2005
I forgot to look it up... But a couple hours sounds OK. The Helm book says something like xx psi allowable in 30(?) minutes or something like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">I forgot to look it up... But a couple hours sounds OK. The Helm book says something like xx psi allowable in 30(?) minutes or something like that.
what section of the helms?
Then I'm probably confused about where I've seen it.
I looked in my '98/'99 Accord Helm book & didn't see it. But still, if it takes a couple hours for the pressure to drop, that sounds OK.
Modified by JimBlake at 7:39 AM 10/27/2005
fryman
Oct 21, 2009 02:39 PM
