folding mirrors
Old Oct 24, 2005 | 01:23 PM
Pootie's Avatar
Default folding mirrors
I have a set of mirrors from a '99 teg on my car. If I get a set of the jdm folding mirrors, does anybody know if I can simply switch out the lens?
Old Oct 24, 2005 | 01:35 PM
5 Speed AP2's Avatar
Default Re: folding mirrors (Pootie)
You mean the mirror? If so, why? Most of the time when you buy the jdm folding mirrors, they come with the mirror.
Old Oct 24, 2005 | 01:43 PM
TunerN00b's Avatar
Default Re: folding mirrors (5 Speed DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pootie &raquo;</TD></TR><TR><TD CLASS="quote">I have a set of mirrors from a '99 teg on my car. If I get a set of the jdm folding mirrors, does anybody know if I can simply switch out the lens?</TD></TR></TABLE>
I believe, but am certainly no expert here, that you can switch out the bracket that holds the mirror in the housing.
You might want to use the actual JDM mirrors instead of the USDM ones though, as I believe that they are blue tinted. If they aren't, I would assume the glass is the same then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed DC2 &raquo;</TD></TR><TR><TD CLASS="quote">You mean the mirror? If so, why? Most of the time when you buy the jdm folding mirrors, they come with the mirror.</TD></TR></TABLE>
Because the JDM mirrors will be angled for the driver to be on the right side of the car, not the left. If you want the normal full range of adjustment, you'll need to use some USDM hardware.
Old Oct 24, 2005 | 01:53 PM
Default Re: folding mirrors (TunerN00b)
oooooooh.
Old Oct 24, 2005 | 04:12 PM
91IntegraX's Avatar
sounds logical to me
Old Oct 25, 2005 | 12:24 AM
EnjoyTheRideDC2's Avatar
NO, you cant. The Backing of the Mirror is not interchangeable. What I mean is: USDM mirror will not simply snap into the JDM unit. What you have to do is seperate the JDM Mirror and Black Plastic backing, do the same to the USDM mirror, and glue the USDM Mirror to the JDM Black Backing. Now, you can snap the mirror into the JDM Housing and have normal viewing out of your mirrors.
Old Oct 25, 2005 | 04:14 AM
Backk InTheDA's Avatar
I hate everything
Default Re: folding mirrors (EnjoyTheRideDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
NO, you cant. The Backing of the Mirror is not interchangeable. What I mean is: USDM mirror will not simply snap into the JDM unit. What you have to do is seperate the JDM Mirror and Black Plastic backing, do the same to the USDM mirror, and glue the USDM Mirror to the JDM Black Backing. Now, you can snap the mirror into the JDM Housing and have normal viewing out of your mirrors.</TD></TR></TABLE>
Good info
Old Oct 25, 2005 | 05:30 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
I just installed my JDM mirrors, and it's a bit weird now, I totally forgot to get the lenses changed out on my USDM ones, and now I somewhat regret it. It's DEF different and it takes some getting used to. Hindsight is always 20/20 though you know?
Old Oct 25, 2005 | 04:23 PM
Default Re: folding mirrors (DAantagonist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">I just installed my JDM mirrors, and it's a bit weird now, I totally forgot to get the lenses changed out on my USDM ones, and now I somewhat regret it. It's DEF different and it takes some getting used to. Hindsight is always 20/20 though you know?</TD></TR></TABLE>
You dont know how many mirrors I went through to figure this out....damn JDM crap...agh
jcsurfer8386EF
16
Jan 12, 2009 04:13 PM
4DrDB8
Aug 4, 2008 08:35 AM
91redteg
Sep 18, 2007 09:11 AM
Rguy
Jun 15, 2004 11:17 AM
