clutch master cylinder going bad?
Old Oct 24, 2005 | 01:14 PM
itsJDMyo's Avatar
Default clutch master cylinder going bad?
recently, my buddies clutch pedal has been acting up. the clutch pedal would work fine. you step on it, and it goes back up. but once you start the car, it might work for a while, but once you step on it, it stays down, and you would have to pull the pedal back up again. we checked, and there is still fluid...could it be the cylinder going bad?
Old Oct 24, 2005 | 01:37 PM
PrinceAli132's Avatar
Default Re: clutch master cylinder going bad? (itsJDMyo)
Check to see if there are any air bubbles in the system. Also feel on top of the clutch and brake pedal and see if you feel any brake fluid, if so your slave or master cylinder is going bad.
Ali
Old Oct 24, 2005 | 05:02 PM
Takumi Fujiwara's Avatar
Default Re: clutch master cylinder going bad? (PrinceAli132)
First sign of Master or slave going is low or no fluid in the reservoir. If you look behind your clutch pedal and you see brownish fluid, it's probably the master cylinder. If you stick your finger in the boot that the slave cylinder sits in and it's all wet, then it's probably the slave... good luck.
JDMswagSerf
Dec 10, 2013 09:47 PM
vlc92189
Nov 6, 2006 08:49 AM
92eg6lsvtec
May 20, 2006 05:56 AM
714JDMBB4
Aug 29, 2005 05:34 PM
aengnr1
Jun 16, 2003 12:23 PM
