Air/Fuel ratio gauge installation
Old Oct 24, 2005 | 09:45 AM
Gdub00lude's Avatar
Default Air/Fuel ratio gauge installation
I checked the archives and could not find an adequate answer so......I just bought an air fuel ratio gauge and all I need to know is which wire off the O2 sensor do I need to hook it up to? I have a 2000 prelude.
Old Oct 24, 2005 | 09:46 AM
The Weather Man's Avatar
If its not digital.....throw it away. It'll do no good. All its going to tell you is that its running rich.
All preludes run rich from the factory. Or do you just want the looks?
Old Oct 24, 2005 | 09:47 AM
mgags7's Avatar
its there in the searching....its also there in the manual, just find the pin on the ecu, it will be easier to wire it over there than underneath the car...
Old Oct 24, 2005 | 09:59 AM
Gdub00lude's Avatar
Default Re: (TheKingPin)
It's for looks right now until I get aem ems w/ a wideband. I just need to know the color of the wire.
ps I have a chiltons manuel and it sucks because it doesn't have a wire diagram for the ecu.
Old Oct 24, 2005 | 10:05 AM
mgags7's Avatar
yes it does, you should look under prelude engine or chassis wiring
it has a diagram of every single pin on the ecu
Old Oct 24, 2005 | 11:16 AM
bubs's Avatar
Default Re: (Gdub00lude)
Should be the white wire (pin #7) on the ecu "D" connector.
Old Oct 24, 2005 | 02:37 PM
Gdub00lude's Avatar
Default Re: (bubs)
Thanks, your the first one to give me a straight answer on this forum.
Wannabe JDM
14
Nov 26, 2005 11:25 AM
vtecb20coupe
Oct 6, 2004 05:02 PM
boostng r
Sep 18, 2004 10:57 AM
riddickone
Nov 26, 2003 10:24 AM
